D
Dimella
Advanced Custom Fields for WordPress
Use the Advanced Custom Fields plugin to take full control of your WordPress edit screens & custom field data.
Add fields on demand
Our field builder allows you to quickly and easily add fields to WP edit screens with only the click of a few buttons!
Add them anywhere!
Fields can be added all over WP including posts, users, taxonomy terms, media, comments and even custom options pages!
Show them everywhere!
Load and display your custom field values in any theme template file with our hassle free developer friendly functions!
Simple & Intuitive
Create a field group, add your fields and define the location rules. Presto! Your fields have appeared and are ready for content.
Made for developers
At the core of the Advanced Custom Fields plugin is the simple and intuitive API. Use functions like get_field() and the_field() to quickly build powerful templates.
v5.7.12
[HIDEL=5]Как увидеть ссылки? | How to see hidden links?
1.89 MB [/HIDEL]
Add them anywhere!
Simple & Intuitive
Made for developers
- Fix - Added missing function register_field_group().
- Fix - Fixed PHP 5.4 error "Can't use function return value in write context".
- Fix - Fixed bug causing wp_options values to be slashed incorrectly.
- Fix - Fixed bug where "sync" feature imported field groups without fields.
- Fix - Fixed bug preventing get_field_object() working with a field key.
- Fix - Fixed bug causing incorrect results in get_sub_field().
- Fix - Fixed bug causing draft and preview issues with serialized values.
- Fix - Fixed bug causing reversed field group metabox order.
- Fix - Fixed bug causing incorrect character count when validating values.
- Fix - Fixed bug showing incorrect choices for post_template location rule.
- Fix - Fixed bug causing incorrect value retrieval after switch_to_blog().
- i18n - Updated Persian translation thanks to Majix.
v5.7.12
1.89 MB [/HIDEL]
