FairStars Audio Converter 1.49
FairStars Recorder 2.62
FairStars MP3 Recorder 1.10
DOWNLOAD ONE PACK (~ 6 MB)!
PASSWORD
Brief Description:
FairStars Audio Converter is a media file conversion tool to convert WAV, RealMedia(RM, RA, RMJ), AIFF, AU, Creative VOC, PVF, IFF, SVX, APE, FLAC, OGG, VQF, MP1, MP2, MP3, WMA, WMV, ASF to WMA, MP3, VQF, OGG, FLAC, APE, WAV formats. You can convert multiple files in a single batch, regardless of their source and target formats. In addition, the program includes a built-in player. The audio format conversions are performed without any temporary files, allowing high conversion speeds. Other features include normalization (adjust volume), support for ID3 tags and more.
Main features
Convert WAV, RealMedia(RM, RA, RMJ), AIFF, AU, Creative VOC, PVF, IFF, SVX, APE, FLAC, OGG, VQF, MP1, MP2, MP3, WMA, WMV, ASF to WMA, MP3, VQF, OGG, FLAC, APE ,WAV formats with different settings.
Fast Conversion Speed: audio format conversion is performed directly without any temporary files, and thus enables high converting speed and economy of hard disk resource.
Batch audio files conversion:You can convert many files in one batch regardless of their source formats.
Support automatic volume adjustment(normalization) when converting.
Support automatic saving ID3 Tags when converting, and also support ID3 tags display and edit.
Playback of Popular Music Formats: support WAV, RealMedia(RM, RA, RMJ), AIFF, AU, Creative VOC, PVF, IFF, SVX, APE, FLAC, OGG, VQF, MP1, MP2, MP3, WMA, WMV, ASF files with its built-in player.
Support Drag and Drop:supports dragging and dropping files or folders from the File Explorer into the window of FairStars Audio Converter.
Explorer-like file input dialog: allows you to navigate through supported files on your computer and add them to File List easily and quickly.
Easy-to-use user-friendly interface.
Note: If you want to convert RealMedia Files(RM, RA, RMJ) to other audio format files, you need install RealPlayer or RealOne on your machine, and you may download it from Как увидеть ссылки? | How to see hidden links?.
Brief Description:
FairStars Recorder is a real-time audio recorder, offering professional recording features with full support for WMA, MP3, OGG, APE and WAV formats. It allows you to record sound directly from your sound card, including from a microphone or a line-in jack at high quality. It can be used to grab any sound, including music, dialogs from movies, game sounds, streaming audio or anything else. The captured sound can be saved directly to WMA, MP3, OGG, APE or WAV format, without the need for temporary files. In addition, the program includes a ID3 tag editor. Additional features include silent skip (Silence Detector), file size limits and more.
Main features
Record audio from sound card directly to WMA, MP3, OGG, APE or WAV format with high quality.
Support writing of ID3 tag when recording and showing when playback.
Skip silent passages, stop recording or record to a new file automatically after a set time silence (Silent Detector).
Stop recording or record to a new file automatically when reaching a set file length, size or time (File Limitation).
Add files to File List automatially (File Append).
Remove environmental noise automatically with the option Filters Setting.
Support ID3 tag view, import, edit, or transfer to the file in File List with TAG Editor and Tag Option.
Easy-to-use user-friendly interface, and HotKeys work in any application.
Wave monitor when recording.
Note: When you record from a microphone or a line-in jack, mark the option "Autosetting" in "Advance" page may remove the environmental noise automatically.
Brief Description:
FairStars MP3 Recorder is a real-time audio recorder, offering professional recording features with full support for MP3, OGG, APE and WAV formats. It allows you to record sound directly from your sound card, including from a microphone or a line-in jack at high quality. It can be used to grab any sound, including music, dialogs from movies, game sounds, streaming audio or anything else. The captured sound can be saved directly to MP3, OGG, APE or WAV format, without the need for temporary files. In addition, the program includes a ID3 tag editor. Additional features include silent skip (Silence Detector), file size limits and more.
Main features
Record audio from sound card directly to MP3, OGG, APE or WAV format with high quality.
http://rapidshare.de/files-en/345763/AFSSP.rar.html
AFsP1-t03.packbys0ul
