G
Gennadiy
Antenna Web Design Studio v2.0.78
эта программа для создания профессиональных вебсайт.
Antenna enables you to develop great looking web sites rapidly. Create a professional web site to promote yourself or your company. Publish your site online or distribute on CD as an interactive CV. Be seen - make a good impression - get noticed!
You can create web pages in minutes, without any HTML knowledge. Antenna's powerful editor is entirely visual, and pixel accurate - putting you in control. Wherever you drag & drop text, pictures, buttons, flash animation and movies on the page, that's exactly where they will appear in the web browser.
When you are ready to publish your site, you won't need to buy any additional software - Antenna has it's own publisher built in, and it can be set to publish changes only, so you can update your site very quickly.
Once your site is up and running why not give yourself a competitive edge and move onto the international scene? Antenna can generate multilingual versions of your web site - all you need to provide is the translations. The beauty is it's easy to maintain too - any future changes to your design and layout are reflected across all languages immediately. You can make just part of your site multilingual too - enabling you to dip your toes into the international scene, without translating your entire site in one go.
And if you need a hand there's a set of free online tutorials and expert tips, a comprehensive 100 page fully illustrated colour User Guide and free technical support.
Key Features
Visual editor for Rapid Site Development
Drag and drop WYSIWYG - Pixel Accurate. Position items exactly where you want them to be. Customisable 'snap-to-grid' facility for easy object alignment.
Full Layers System with Layer Transparency
You can build your web pages in layers, place related items on the same layer, add new layers, overlap items and change layer opacity for translucent effects.
Master Pages
Include any page as a layer on any other page. Brilliant for themes - If you change a master page, the change will be reflected instantly across all other pages that reference it!
Design with Style - CSS Styles Editor built in
Perfect your look, and make sweeping visual changes across the whole site quickly and simply.
Rollover Buttons and Special FX
Shadows, motion blur, neon, water - all done visually, no HTML coding required.
Add Audio and Video to your web pages
Supports AVI, MPEG, QuickTime and Flash.
Object Properties Palette
No need for complex modal dialog boxes - modify items using a floating palette and see the results instantly. Very quick - once you know how to edit one type of object, you know how to edit them all.
Single File Project
A website is saved as a single file on disk - very easy to manage. Organise your web and move files around at any time without having to worry about broken links - Antenna keeps links updated automatically.
Integrated Button Graphics Maker
Create high-quality button graphics with Antenna's built in Button Lab. Features presets so you can build up a library of buttons.
Integrated FTP Publisher
Includes a 'Publish Changes Only' option for rapid site updates.
оффсайт.
_http://www.stormdance.freeserve.co.uk/dx/antenna/key%20features.htm
качать.
_http://www.piaodown.com/down/down.asp?id=4198&no=1
4 .22 мг.
Key Features
Master Pages
Single File Project
оффсайт.
качать.
4 .22 мг.
