Applied Flow Technology Impulse v3.0.2005.01.10
N
-=Neon=-
Applied Flow Technology Impulse v3.0.2005.01.10 - специализированный софт стоимость 6000$. Стало лень переводить так что:
Waterhammer analysis tools of the past have been noted for being difficult to use and requiring extensive specialized knowledge. As a result, this critical aspect of piping system design and operation has often been overlooked. But no longer. Now AFT Impulse™ offers the ease-of-use of a drag-and-drop interface and built-in waterhammer modeling expertise. AFT Impulse helps you design and operate your systems with greater reliability and safety by avoiding the potentially catastrophic effects of waterhammer and other undesirable system transients.
Piping systems engineers typically do not have the time to become specialists in waterhammer modeling. Now they don’t have to. Now they can be equipped with the proper tools to design and analyze for waterhammer transients in liquid systems containing water, petroleum and chemical products, cryogens, refrigerants and more. Waterhammer specialists will find a no compromise tool capable of modeling a broad range of waterhammer events, including transient cavitation and various surge suppression devices. AFT Impulse provides a built-in library of fluids and fittings, variable model configurations, pump and control valve modeling and much more. Scenario Manager raises the what-if potential of waterhammer modeling to a new level. Multiple system configurations varying by any modeling parameter are easily managed within a single model file with a familiar hierarchical interface. Changes in the base model are automatically inherited by alternate design cases.
AFT Impulse incorporates a steady-state solver providing seamless transfer of initial conditions to the transient analysis. The traditional Method of Characteristics are employed to solve the transient mass and momentum equations of pipe flow. Modeling vapor cavitation and liquid column separation, the effect of pressure surges due to vapor cavity collapse may be evaluated. Modeling tools for a wide range of system components and surge devices are included. Transients can be initiated based on time or on events in the system. For example, a valve closure transient may be initiated when a specified pressure level is attained at a location. From the powerful drag-and-drop model building features to the fully customizable output, AFT Impulse is a powerful tool ready to tackle your most demanding design problems.
Размер: - 20Х1.44MB
Домашняя
http://www.aft.com/products/impulse/
Скачать
Лекарство не пробовал прошу отписаться у кого все нормально прошло !!!
Лечим
Felixz сказал(а):
Вобщем, мужики, посидел я и поковырялся - забирайте серийник:
0930-xxxxх, вместо "х" любые символы.
Класс, как раз аудитом Районных тепловых станций Москвы сейчас занимаюсь... там именно проблемы совместной работы насосов с ЧРП (частотно-регулируемым приводом) - никто просчитать не может саму возможность их совместной работы (по гидравлике РТС - тепловая сеть)...
Распокавал, серийник в кряке дается (файл EAT.nfo) такой:
1. Unpack and install (run setup.exe).
2. Use this serial number when asked: 3471502004
Answer NO to token stuff message (you don't have it, do you?)
3. Copy the files from the \crack dir to the program's folder,
overwriting the original file(s).
That's all. Have fun using it! :)
но этот номерок (3471502004) неработает при запуске инсталлятора (там еще спрашивают имя и company) - может сдесь затык (номерок работает с определенным
name и company)?
Вопрос - где найти (если можно, напиши в конфу ;)???
Нужная весчь :)!
С Уважением,
Евгений
Есть такая прога по расчету трубопроводов - Старт (версия 4.40)
Офсайт _http://www.truboprovod.ru/cad/soft/ctapt.shtml
и еще _http://www.cadmaster.ru/articles/08_start.cfm
Если кому интересно, могу выложить - все серийники в комплекте подходят:)
ПРОГРАММА РАСЧЕТА И ПРОЕКТИРОВАНИЯ ТРУБОПРОВОДНЫХ СИСТЕМ
Очень интересует, выложи пожалуйста.
Старт - это расчет на прочность трубопроводов, а гидравликой и не пахнет.
Прогау наверно ктот с работи спер а расглашат своиу компаниу не охота))))))))))) вот отсуда и проблеммка)))))) А прога деиствително нелихаиа)))))))
Поиск по всяким асталавистам и прочая ничего не дал - серийник к прошлым версиям почти такой же - отличается только последней цифрой - не 4 а 3 (похоже на год).
Перебор этой цифры тоже ничего не дал :(
А что-нибудь подобное для электриков не найдется?
