Blumentals Easy Button and Menu Maker Pro.v1.0 Portable
ergir
With Easy Button & Menu Maker you can easily create sophisticated buttons and professional dynamic menus for your website while investing just a few minutes of your time. More than 100 elegant design templates are included, reflecting various design styles such as so called Glass and Vista style. Unlike most other menu tools, Easy Button & Menu Maker provides direct WYSIWYG visual menu editor, so it is much easier and pleasant to work with. Menus created with Easy Button & Menu Maker are quick, compact and compatible with all modern web browsers.
Key Features
* Easily create cool web buttons
* Easily create dynamic multi-level website menus
* Direct visual WYSIWYG menu editor
* Use fonts of your choice
* Add icons to the buttons and menus
* Easily insert created buttons and menus in your website
* All Web browsers and systems are supported
* The generated code is valid and standards compliant
* GIF, PNG and JPEG image formats are supported
Why choose Easy Button & Menu Maker?
* You get 2 great tools in a single package – button maker and menu maker
* Very latest Glass and Vista visual styles are supported
* Created menus are fast and lightweight
* Created menus do not require any additional software like Java and Flash
* Created menus are search engine friendly
* Generated code is valid according to XHTML 1.0 and CSS standards
download
size- 4121 KB
http://rapidshare.com/files/94893419/Blumentals-Easy-Button-and-Menu-Maker-Pro.v1.0-Portable.exe
