Source Insight is a project-driven editor, code scanner, and powerful analyst that helps you understand code better.
This program is a dynamic analyzer for C / C ++, C #, Java, Objective-C languages.
Easily view hierarchy of methods and estimate the cost of new changes by examining the inheritance and internal dependencies of the code. With its powerful scanner, it's easy to navigate between functions and variables.
All functions and variables used in the code are displayed. Referrals, classes, and all internal communications are displayed. With smart search, you can find the codes you want within the project. This program dynamically analyzes the codes and updates the most recent changes in all reports at any given time.
In the auto-complete section, you can also use snippets, auto-checklists, and smart-name modifiers. In addition, methods, variables, and references are displayed based on the description, scope and usage.
Features Source Insight:
- Help understand the current codes
- Quick scrolling between functions and their recalls
- Find referrals to functions, variables and ...
- Representation of the method of graph reading and tree classes of classes
- Preview functions and define classes without opening the destination file
- Live representation of references to variables and other items with syntax and specific format
- Powerful editing capabilities include the Snippet code, auto-completion code, and smart rename
- Dynamic information display panel
- Ability to customize template and syntax
- Beautify codes and adjust auto-spacing and empty space
- Highlighted auto reference
- Code previews when scrolling
- Possibility to use multiple layouts simultaneously and side by side
- Advanced search with search functionality
- more info Как увидеть ссылки? | How to see hidden links?
- OS: Windows XP / 2000, Windows NT 4.0 SP3 +, Windows 98 / Me, Windows 95 with Internet Explorer 4.0+
- Machine: Pentium or faster, Pentium II or better recommended.
- Memory: 64 MB, 128 MB or more recommended.
- Disk Storage: 4 MB min installation, 12 MB full install.
Hidden content. You need to Как увидеть ссылки? | How to see hidden links? or Как увидеть ссылки? | How to see hidden links?.
