G
Gennadiy
Cucusoft MPEG AVI to DVD VCD SVCD MPEG Pro v6.08
эта программа позволяет преобразовывать файлы фортама:AVI в MPEG1 и MPEG2.
также вы можете обьеденить несколько видео клипов в один файл MPEG.
Cucusoft is the leader in helping people convert AVI to VCD / AVI to DVD / AVI to SVCD - for memories, for entertainment. We are the World's Leading Video Converting Company.
The first commercialized "AVI to VCD/DVD/SVCD converter" in the world is made by our company. Our AVI Converter almost becomes the industrial standard among current popular converters. Other AVI Converters have begun to imitate our functions and design of User Interface. We keep improving our functions and performance, with an aim to keep our products at the first position of market. You can visit C|Net(download.com) to check that the download number of our "AVI to VCD/DVD/SVCD Convert" far go beyond other competitors.
Including all the features of the basic version, "Cucusoft AVI to DVD VCD SVCD MPEG converter Pro" enables you to convert AVI files directly to MPEG1 and MPEG2 whose dimension is at your control. In addition, you may merge several video clips into one MPEG file or convert multiple videos in one batch with the new Pro features. Now you can get this All-in-One video converter at such a competitive price!
оффсайт.
Features of Cucusoft AVI to VCD/DVD/SVCD Converter Pro
Convert avi to VCD/DVD/SVCD compatible mpeg file
Support .VOB, .asf, .wmv format as input file
Support DivX, XviD avi format
Support MPEG1, MPEG2, MPEG4 video format
Support MPEG layer1, layer2, layer3 audio format
Color correction function.
Support Subtitle, you can add subtitle onto your output movie. (You need to install VobSub software first.)
"Split function" to cut a big mpeg file into several smaller parts to fit a CD-R capacity
Support both TV systems: NTSC/PAL
Input/Output preview
Two output modes: Stretch to Fit / Lock Aspect Ratio
High audio quality
Can output *.m2v and *.mpa for DVD authoring
Support no sound avi files
Optimized for Intel Pentium 3 and Pentium 4 processors and AMD Athlon
Batch Function, Support converting multiple avi files to DVD VCD SVCD MPEG1/2 at the same instance
Merge/Join function, Support selecting several avi clips from different sources and combine them into one single output
оффсайт.
http://www.avi-vcd.com
качать комплект..
_http://www7.piaodown.com/softka/Cucusoft.MPEG.AVI.to.DVD.VCD.SVCD.MPEG.Converter.Pro.v6.08.rar
_http://www.piaodown.com/down/down.asp?id=12643&no=1 4.0 мб
оффсайт.
High audio quality
оффсайт.
качать комплект..
