CyberMotion 3D Designer v12.2.5.5 Portable
ergir
Wherever we look, we encounter virtual worlds. Whether in Hollywood or daily advertisements, the world that is presented to the viewer will be a mainly artificial creation. At last, you too can create these surreal worlds at home, practice inside or outside architecture, design products or promotional logos and films or build your own virtual worlds using the build in landscape designer and atmospheric background models. All the modules that you need to generate, model and manipulate, animate and represent the three-dimensional world are integral parts of the CyberMotion 3d-software.
CyberMotion provides a high quality rendering output using raytracing and up-to-date global illumination algorithms like Ambient Occlusion and Photon Mapping. The possibilities to define object surfaces, light conditions and backgrounds are almost inexhaustible - visual libraries and fast preview windows in the main dialogs invite to experiment and play around with this vast functionality.
Complex 3D animations can be set up very easily - you can animate all objects, camera and light settings, backgrounds, fire, water and even clouds and fog in the atmosphere. You can arrange objects in hierarchies to animate jointed models or robots and easily position joints with the help of Inverse Kinematics. And with the up to date Skin and Bones technology even character animation is available with CyberMotion. Call your own heros and monsters into being, CyberMotion gives you all the tools you need to do it.
User Interface
The graphical user interface allows you to design complex 3D scenes while working in multiple windows simultaneously. Just select an object and drag it with your mouse to move, scale, rotate or deform it in the corresponding work modes. Clearly arranged dialogs containing visual libraries make it easy to load prefabricated files and to modify them to your own needs. Big preview windows in the main dialogs provide a quick overview of the scene, so just play around and test everything. With the multiple Undo/Redo-functions almost everything can be undone or redone, respectively.
Program Help and Printable Manual
Along with CyberMotion 3D-Designer comes a rich illustrated context-sensitive help manual with lots of tutorials and examples. Context sensitive help can be obtained at any time pressing the F1-key. In addition, registered users can download a revised printable version of the help file on our download section (PDF document, about 450 pages).
download
size- 42579 KB
http://rapidshare.com/files/86546044/CyberMotion-3D-Designer-v12.2.5.5.exe
Реакции: Luz
