B
Bobson
DVB Viewer Pro 3.6.1.2
Программное обеспечение для просмотра спутниковых цифровых ТВ каналов. Так же позволяет просматривать телетекст и телегид (EPG - электронное расписание передач), записывать "на лету" и воспроизводить ТВ каналы в форматах MPEG2, Divx, AVI и M2V, настроить сценарии записи. Все это многообразие функций дополняется предустановленным списком каналов, почти для всех существующих спутников, которые так же можно редактировать, сохранять в отдельные файлы и формировать списки любимых каналов.
На буржуйском:
DVBViewer allows you to experience Digital TV on your PC. With a proper DVB card you can enter the world of digital entertainment and experience high quality, incredibly sharp TV pictures and near CD quality radio!
What features does DVBViewer provide?
It provides all basic functions you need to enjoy digital television and radio programs. In addition, DVBViewer offers you a wide range of advanced features such as Teletext, Electronic Programming Guide, Remote Control support and enhanced recording capabilities which enable you to record your favourite shows on hard-disc, edit them or share them with your friends.
Which features make it unique?
DVBViewer contains functions which are groundbreaking : It was the first program with a so called DesktopTV mode and in its category the only product which offers AC-3 and Timeshifting features. It is even possible to handle more than one DVB device at the same time. Further on the multimedia skills of the DVBViewer do not need to hide behind other mediacenters. From playing multimedia contents up to receiving RSS newsfeeds, weather data, everything is possible.
What's new:
Version 3.6.1.20
[*] Fix: Vista Titlebar was not hidden in fullscreen mode
[*] Add: new turkish language
[*] Add: partially CI support for KNC1 Adapters (KNCBDACTRL.dll required)
[*] Change: removed post processors
Version 3.6.1
* Fix: ATSC EPG works again
* Fix: Shoutcast Filter is now part of the installer again
* Fix: game gravitron works now
* Change: Channellist is saved automatically after channelscan.
* Change: Timers.xml is saved after most changes.
* Change: Favorites are written now when pressing the save button.
* Fix: knc detection
* Fix: MultiCore CPU settings did not worked properly.
* Fix: DVD-Prev Chapter was not working.
* Change: Forms outside the monitor are now repositioned
* Add: Popup menu in Mainwindow now shows the filterlist.
* Change: All filters are listed in Filterlist.
* Fix: COM: ChannelID was still calculated the old way.
* Change: On saving a backup of Timers.xml is created.
* Change: 10x tuning limit removed
* Change: USALS (E/W, N/S now possible).
* Change: now replaced with .
* Change: Subtitles: Now there is always a entry Subtitles -> None, in case a channel transmits only "No subtitles available" (ttx ZDF). Before you couldn't disable this, case it was not marked as subtitle page...
* Change: TTx Subtitles: On switching channel now subtitles are cleared.
* Fix: Wrong AC3 decoder detection.
* Fix: Instancehandling in Vista.
* Fix: Mp3 Decoder handling.
* Fix: Skystar 2 <-> Server4PC conflict.
* Fix: Filedevice: Didn't work.
* Change: Plugins can now retrieve the whole multiplex
* Change: More Vista compliant Icons
Version 3.6.0.0
[*]Add: Added recordingservice.
[*]Fix: EPG-Window: Fixed "&" was replaced by "_" in Timeline.
[*]Add: Recorderwindow: Added play running recording to contextmenu.
[*]Add: Recorderwindow: Added doubleclick on running recording switches to the channel the timer is recording.
[*]Fix: COM-Events: Fixed several glitches.
[*]Fix: Siehfern: Fixed endless loop in receiving due to too small buffers.
[*]Add: Channels/EPG: Added selection for EPG-Source in chaneleditor.
The source:
- DVB EPG: EIT, ATSC and Premiere Portal EPG.
- Internal EPG: SiehFernInfo, MHW(+)
- External EPG (for EPG-Importers)
Default is: allow all sources.
[*]Change: OSD: When changing to subpages the selection in the EPG and channelwindows now is remembered.
[*]Fix: OSD: fixed pagecounter of lists.
[*]Fix: CAM: Fixed missing first entry in MMI menu on some CAMs. General improvement of CAM/CI support.
[*]Fix: EIT-EPG: Fixed loosing of entries in Kabel1/Pro7/Sat1 austria.
[*]Fix: Vista support: Fixed several issues with vista.
[*]Change: Signaldisplay: changed signal display for some pinnacle and terratec devices.
[*]Change: Added a splitter to some windows so the Headerpanel can be hidden by mouse.
[*]Change: OSD-Properties: added some properties regarding picture handling of epg entries.
[*]Fix: Radiomode: fixed a bug when starting viewer in radio mode.
[*]Update: Language: updated several language files.
Size: 7.61 Mb (7980993 bytes)
На буржуйском:
What's new:
Version 3.6.1.20
Version 3.6.1
Version 3.6.0.0
The source:
