Gadwin Print Screen Pro v4.4.1211 Portable
ergir
Gadwin PrintScreen captures the contents of the screen with a single keystroke. The captured screen can then be sent to the printer, or saved to disk as a file in 6 different graphics file formats.Gadwin PrintScreen can capture the entire Windows screen, the active window, or a specified area, when the hot key is pressed. The hot key defaults to the PrintScreen key, but users may also define other keys to initiate a capture. Gadwin PrintScreen allows you to e-mail the captured images to recipients of your choice.
Gadwin PrintScreen Professional combines the power of a first-class screen capture application with an advanced image editing and annotation utility - wrapped into one easy-to-use tool.
Who needs Gadwin PrintScreen?
Screen captures can be used for many reasons. Use captured images from Gadwin PrintScreen to show off your product on the web. Enhance technical or sales documents and embed captures into presentations. Gadwin PrintScreen can help you capture and print or save computer screen data.
On most Windows computers a full screen of data can be put on the clipboard by pressing the PrintScreen key. This sends whatever you see on screen to the clipboard, which you must then edit in a different graphics program to cut to the right size and image format. Here are some other reasons not to use the prefabricated PrintScreen function of Windows:
-- Full screen of data can be put only on the clipboard.
-- It is either difficult or impossible to capture some elements of a Windows screen, such as different shaped cursors.
-- You spend too much time making image captures.
Use Gadwin PrintScreen to save time and enhance your screen shots!
download
size- 3233 KB
http://rapidshare.com/files/87092399/Gadwin-Print-Screen-Pro-v4.4.1211-Portable.exe
