D
demo
Audio DVD Creator v1.9.1.0
вы сможете создать Audio DVD-диски собранные из нормальных звуковых CD и файлов MP3, и прослушивать его на любом DVD проигрывателе, как вы это делаете с обычным видео.
У вас есть выбор звукового формата высокого качества (до 6 часов PCM 48kHz/16bits) или большого объема (до 45 часов AC3 192kbps).
Audio DVD Creator is a revolutionary tool that changes the way you listen to your favorite music. You can create DVD disc compiled from normal Audio CDs and MP3 files, and play it on any DVD player since it's DVD-Video compliant. You can choose the audio format from high quality (up to 6 hours PCM 48kHz/16bits) or high quantity (up to 45 hours AC3 192kbps).
Features:
- Put several (about 5-6) Audio CDs on one DVD with perfect audio quality.
- Put thousands of audio files on one DVD with top audio quality.
- Create DVD menu automatically.
- Create up to 99 DVD titles.
- Burn the Audio DVD to DVD-R/RW and DVD+R/RW directly.
- Create the Audio DVD to hard disk files.
- Output format is DVD-Video compliant, so that it can be played by any DVD player.
- Rip Audio CD to WAV files, and import them to Audio DVD directly.
- Import 96kHz/24bits WAV files, and keep the superb quality.
- Import Windows Media Format(.wma, .wmv, .asf), Real Media(.rm), OGG, FLAC, AC3 and AVI files via DirectShow Filters.
- Preview shows an overview of your Audio DVD.
- Save/Load your project, and edit it anytime.
- Blazing fast speed, only need about 30 minutes to create a PCM format Audio DVD. For AC3 format, it may need several hours.
- Easy to use: the wizard will guide you step by step - very suitable for beginners!
System Requirement:
- Windows 95/98/Me, NT/2000/XP, Server 2003
- Pentium II 500 MHz
- 128 MB of RAM
- 5 GB of Free Hard Disk Space
- A DVD-R(W) or DVD+R(W) Drive
оффсайт.
_http://www.audio-dvd-creator.com/
качать.
Как увидеть ссылки? | How to see hidden links? 4/3 мг.
Features:
System Requirement:
- 128 MB of RAM
оффсайт.
качать.
Hidden content. You need to Как увидеть ссылки? | How to see hidden links? or Как увидеть ссылки? | How to see hidden links?.
