help me VC++ code convert to Delphi code
huayan889
#define MAX_M_NUM 256
#define MAX_P_NUM 64
#define MAX_T_NUM (32*MAX_P_NUM)
enum REMOVE_STATE
REMOVE_STATE_NONE = 0,
REMOVE_STATE_START = 1,
REMOVE_STATE_READY = 2,
enum M_STATE {
M_Free,
M_CC_INPUT,
M_CC_OK,
M_M_INPUT,
typedef struct
char m_s32FType;
short m_s32FCnl;
}CallID_t;
typedef struct
long m_s32DevMain;
logn m_s32ID;
long m_s32DevNum;
}Dev_List_Head_t
typedef struct
short m_s16Main;
short m_s16Sub;
Char m_s8ID;
Char m_Ru1[1];
short m_s16ID;
short m_s16Group;
char m_Ru2[2];
CallID_t m_CallID;
}DeviceID_t;
typedef struct
Char m_s8ID;
short m_s16ID;
}CNL_MAP_TABLE;
typedef struct
DeviceID_t deviceID;
int iSeqID;
M_STATE ModuleState;
} T_STRUCT;
typedef struct
unsigned long m_s32Handle;
DeviceID_t m_DeviceID;
long m_s32ESize;
long m_s32EType;
}Evt_t;
enum V_STATE {
V_WAITOPEN,
V_FREE,
V_USED,
V_WAIT_REMOVE
typedef struct
int iSeqID;
DeviceID_t UsedDevID;
V_STATE State
} V_STRUCT;
typedef struct
int iSeqID;
Byte u8E1Type;
} P_STRUCT;
DEVICE_RES AllDeviceRes[MAX_M_NUM];
int iTotalM = 0;
char MapT_M[MAX_M_NUM];
int iTotalP = 0;
int iTotalPOpened = 0;
CNL_MAP_TABLE MapT_P[MAX_P_NUM];
int iTotalT = 0;
int iTotalTOpened = 0;
CNL_MAP_TABLE MapT_T[MAX_T_NUM];
int iTotalV = 0;
int iTotalVOpened = 0;
int iTotalVFree = 0;
CNL_MAP_TABLE MapT_V[MAX_T_NUM];
//the above define and struct is description for the follow statements, not necessary for convert -------
typedef struct
long lFlag;
int iSeqID;
bool OpenFlag;
bool ErrFlag;
REMOVE_STATE RemoveState;
long lVNum;
long lVOpened;
long lVFreeNum;
V_STRUCT *pV;
long lPNum;
long lPOpened;
P_STRUCT *pP;
long lTNum;
long lTOpened;
T_STRUCT *pT;
}DEVICE_RES;
#define M_OneV(DevID) AllDeviceRes[(DevID).m_s8ID].pV[(DevID).m_s16ID]
#define M_OneP(DevID) AllDeviceRes[(DevID).m_s8ID].pP[(DevID).m_s16ID]
#define M_OneT(DevID) AllDeviceRes[(DevID).m_s8ID].pT[(DevID).m_s16ID]
DJ_S32 PlayFile ( DeviceID_t *pVDevID, char *s8FileName, byte u8PTag, bool bIsQueue = false );
void TWork ( T_STRUCT *pOneT, Evt_t *pEvt );
extern int iPWork;
void DispEvtInfo ( Evt_t *pEvt )
char TmpStr[256];
char TmpS[128];
Dev_List_Head_t * pDevList = NULL;
sprintf ( TmpStr, "EVT(%4d) : ", pEvt->m_s32ESize );
switch ( pEvt->m_s32EType )
case E_QUERY_DEV:
pDevList = (Dev_List_Head_t *) FetchEventData(pEvt);
default:
break;
void CloseDeviceOK ( DeviceID_t *pDevice )
T_STRUCT *pOneT;
if ( pDevice->m_s16Main == DEVMAIN_PORT )
M_OneP(*pDevice).bOpenFlag = false;
void OpenAllDevice_D ( char s8ModID )
int i;
for ( i = 0; i < AllDeviceRes[s8ModID].lVocNum; i++ )
OpenVocDevice ( &AllDeviceRes[s8ModID].pV );
void HandleState ( Evt_t *pEvt )
T_STRUCT *pOneT;
P_STRUCT *pOneP;
if ( pEvt->m_DeviceID.m_s16Main == DEVMAIN_PORT )
pOneP = &M_OneP(pEvt->m_DeviceID);
pOneP->u8E1Type = (pGenData->m_s32DevState >> 16) & 0xFF;
void FreeOneDevRes ( int ID )
if ( AllDeviceRes[ID].p != NULL )
delete [] AllDeviceRes[ID].pV;
memset ( &AllDeviceRes[ID], 0, sizeof (DEVICE_RES) );
void RefreshMapTable ( void )
int i, j;
int TCount, VCount, PCount, MCount;
int iModSeqID;
MCount = TCount = VCount = PCount = 0;
for ( i = 0; i < MAX_M_NUM; i ++ )
if ( AllDeviceRes.lFlag == 1 )
AllDeviceRes.iSeqID = MCount;
MapT_M[MCount] = i;
iModSeqID = 0;
for ( j = 0; j < AllDeviceRes.lTNum; j ++ )
AllDeviceRes.pT[j].iSeqID = TCount;
MapT_T[TCount].m_s8ID = AllDeviceRes.pT[j].deviceID.m_s8ID;
if ( AllDeviceRes.pT[j].deviceID.m_s16Sub != DEVSUB_UNUSABLE )
AllDeviceRes.pT[j].iModSeqID = iModSeqID;
void AddDevRes_T ( char s8ModID, Dev_List_Head_t *pDevList )
DJ_S32 s32Num;
int i;
char TmpStr[256];
s32Num = pDevList->m_s32DevNum;
if ( (AllDeviceRes[s8ModID].lTNum == 0) && (s32Num > 0) )
AllDeviceRes[s8ModID].pT = new T_STRUCT[s32Num];
if( !AllDeviceRes[s8ModID].pT )
AllDeviceRes[s8ModID].lTNum = 0;
sprintf ( TmpStr, "new T_STRUCT[%d] fail in AddDevRes_T()" );
else
memset ( AllDeviceRes[s8ModID].pT, 0, sizeof(T_STRUCT)*s32Num );
DeviceID_t *pDev;
pDev = (DeviceID_t *)((BYTE *)pDevList + sizeof(Dev_List_Head_t));
for ( i = 0; i < s32Num; i ++ )
AllDeviceRes[s8ModID].pT.deviceID = pDev;
AllDeviceRes[s8ModID].pT.State = T_WAITOPEN;
else if ( (AllDeviceRes[s8ModID].lTkNum > 0) && (s32Num == 0) )
for ( i = 0; i < AllDeviceRes[s8ModID].lTNum; i ++ )
if ( AllDeviceRes[s8ModID].pT.State != T_WAITOPEN )
CloseDeviceOK ( &AllDeviceRes[s8ModID].pT.deviceID );
delete [] AllDeviceRes[s8ModID].pT;
AllDeviceRes[s8ModID].pT = NULL;
Void E_Handler( unsigned long ePrm)
Evt_t * pEvt = NULL;
pEvt = (Evt_t *) ePrm;
DispEvtInfo ( pEvt );
case EVT_QUERY_DEVICE:
if ( ( iPWork == 0 ) || (pEvt->m_DeviceID.m_s8ID == iPWorkID) )
pDevList = ( Dev_List_Head_t *) FetchEventData(pEvt);
AddDeviceRes ( pDevList );
break;
case EVT_OPEN_DEVICE:
OpenDeviceOK ( &pEvt->m_DeviceID );
break;
default:
if ( pEvt->m_DeviceID.m_s16Main == DEVMAIN_CH )
TWork ( &M_OneT(Evt->m_DeviceID), pEvt );
else if ( pEvt->m_DeviceID.m_s16Main == DEVMAIN_V )
DeviceID_t *pDevID;
pDevID = &M_OneV(pEvt->m_DeviceID).UsedDevID;
if ( pDevID->m_s16Main == DEVMAIN_CH )
TWork ( &M_OneT(*pDevID), pEvt );
break;
memcpy( pParam->m_CT.m_u8NumH, TmpStr, pParam->m_CT.m_u8NumHLen );
//:confused::confused::D:D
//Everybody Merry Christmas Спасибо
