Kellyware KCam v.4.0.21
Home: Как увидеть ссылки? | How to see hidden links?
KCam Router/Mill software is designed to run low cost hobby CNC equipment.
Program your paths using the built in Gcode editor, or import DXF, NC, and
PLT files. Create signs and plates using your CAD software and import your
work into KCam. Dual cutting depth allows for holes and outlines to be
punched out after routing. No more drilling holes for switches or cutting
plates to size before engraving.
Engrave signs, make name tags, drill printed circuit boards, mill parts,
plasma cuts, plot pictures onto paper...
Here are a few of the key features:
- Load GM code files
- Import Excellon ASCII drill files (.NC)
- Import DXF files (.DXF)
- Import HPGL files (.PLT)
- Import Gerber files(.GB0)
- Edit/Write GM code files
- 3D Graphical Viewer w/ Zoom, Pan and Table Views
- Manual Jogging motor control
- Controller and Table setup features
- Supports Parallel Port (LPT) Stepper Motor Controllers
- Selectable Feed Rate
- Backlash Compensation
- Windows 98/NT/2000/XP 32bit Software
- PCB Isolation conversion from Gerber(RS274X) files
- Constant Velocity Contouring
- Multiple Machine Setups
Hidden content. You need to Как увидеть ссылки? | How to see hidden links? or Как увидеть ссылки? | How to see hidden links?.
