News/Info Microsoft releases Edge Dev 88.0.702 with text notes in Edge
Lilix
itclub.me
Команда форума
Admin
It's Tuesday, so as usual, there's a brand new Edge build available in the Dev channel. This week's Edge Dev build is Как увидеть ссылки? | How to see hidden links?, and there's actually quite a bit in the way of new features. Also, the blog post didn't say anything about moving to Edge 89 next week or anything, but it should be fairly soon since Edge 87 is slated to arrive in the stable channel this week.
One of the new features is the ability to add text notes to PDFs. Also, the browser can now automatically find and show coupons while you're shopping. It's actually a pretty significant update with some fun new features. Here's everything that's new:
  • Added the ability to add text notes to PDFs. Note that support is limited to Windows for now. For more details, see Как увидеть ссылки? | How to see hidden links?....
  • Added the ability for Edge to proactively find and show coupons while shopping. Note that this feature is not available for work and school accounts.
  • Rolled out support for automatic deduplication of favorites more broadly. Now, deduplication will occur every time favorites are synced to the device.
  • Added the ability to take a screenshot of the entire webpage using Web Capture.
  • Added settings to the Pinning Wizard to generate more default suggestions.
  • Added support in the IE mode sitelist to be able to specify schemes (http/https) alongside the host and path.
  • Added new management policies to configure whether or not Sleeping Tabs are Enabled, to configure the Timeout until they go to sleep, and to configure the list of URLs that are Blocked from going to sleep. Note that updates to administrative templates or documentation may not be available yet.
  • Enabled support for the management policy to Block External Extensions from Chromium.
  • Updated icons across Edge to be more consistent with the Fluent design scheme.
And of course, there are a bunch of fixes and known issues. Here's what got fixed for improved reliability:
  • Fixed an issue where adding a favorite directly from the Favorites management page sometimes crashes the browser.
  • Fixed an issue where Edge’s first startup after rebooting a device sometimes hangs.
  • Fixed an issue where using the Favorites menu sometimes crashes the browser.
  • Fixed a crash when closing the browser.
  • Fixed an issue where PDFs sometimes crash.
  • Fixed a crash when closing a PDF.
  • Fixed a crash when printing a PDF.
  • Fixed a crash when closing popups.
  • Fixed a crash when shutting down the browser.
  • Fixed an issue where signing into a browser profile that has previously been signed out of will sometimes crash the browser.
  • Fixed an issue where the F6 key sometimes crashes the browser.
  • Fixed a crash when closing the Sleeping Tabs awareness dialog.
  • Fixed a crash when opening a PDF that will end up in an Application Guard window.
  • Fixed an issue where websites installed as apps sometimes won’t launch on Windows Server or other Windows accounts that elevate everything by default.
  • Fixed an issue where pages sometimes crash on load.
  • Fixed a crash when navigating to websites.
  • Fixed a hang during browser shutdown.
Here are the fixes for changed behavior:
  • Fixed an issue where installing a website as an application sometimes fails if the site has already been pinned to the Taskbar.
  • Fixed an issue where pinning Edge to the Taskbar sometimes results in a second copy of Edge on the Taskbar.
  • Fixed an issue where the feedback dialog doesn’t appear.
  • Fixed an issue where adding a site to the “Do not clear” list in the setting to clear cookies and other site data when the browser is closed sometimes fails.
  • Fixed an issue where dragging and dropping favorites to rearrange them from the Favorites menu sometimes results in the favorites being dropped in a different place than shown or intended.
  • Fixed an issue where the indicator that a tab is playing audio sometimes doesn’t appear for certain types of media.
  • Fixed an issue where sorting or filtering cookies on the Cookies management page sometimes fails.
  • Fixed an issue where closing a Web Capture too quickly after copying it sometimes results in the copy failing.
  • Fixed an issue where Guided Switch sometimes opens the wrong page when links are redirected from personal profiles to work/school profiles.
  • Fixed an issue where navigations that are redirected to full IE leave behind a blank tab in Edge.
  • Fixed an issue where the management policy to set the Printing Paper Size Default doesn’t work.
  • Fixed an issue where the Information Protection icon sometimes appears in the address bar when it shouldn’t.
  • Fixed an issue where certain UI text isn’t visible when using custom themes.
  • Deprecated the management policy to enable Proactive Auth.
  • Temporarily removed the ability to pin a website installed as an app to the desktop or Start Menu from edge://apps. Note that generic websites can still be pinned to the Taskbar and Start Menu from … > More tools.
Finally, here are the known issues:
  • Certain extensions such as the Microsoft Editor extension don’t work on Linux. As soon as they’re installed, they crash and are disabled. We’re currently investigating.
  • Users of certain ad blocking extensions may experience playback errors on Youtube. As a workaround, temporarily disabling the extension should allow playback to proceed. See Как увидеть ссылки? | How to see hidden links?... for more details.
  • Some users are still running into an issue where all tabs and extensions immediately crash with a STATUS_INVALID_IMAGE_HASH error. The most common cause of this error is outdated security or antivirus software from vendors like Symantec, and in those cases, updating that software will fix it.
  • Users of the Kaspersky Internet Suite who have the associated extension installed may sometimes see webpages like Gmail fail to load. This failure is due to the main Kaspersky software being out of date, and is thus fixed by making sure the latest version is installed.
  • Some users are seeing favorites get duplicated after we made some previous fixes in that area. The most common way this is triggered is by installing the Stable channel of Edge and then signing into it with an account that has already signed into Edge before. Fixing this should be easier now that the deduplicator tool is available. However, we’ve also seen duplication happen when running the deduplicator on multiple machines before either machine has a chance to fully sync its changes, so while we wait for some of the fixes we’ve made to come to Stable, make sure to leave plenty of time in between runs of the deduplicator.
  • After an initial fix for it recently, some users are still experiencing Edge windows becoming all black. Opening the Browser Task Manager (keyboard shortcut is shift + esc) and killing the GPU process usually fixes it. Note that this only appears to affect users with certain hardware and is most easily triggered by resizing an Edge window. For users with discrete GPUs, updating graphics drivers may help.
  • Some users are seeing “wobbling” behavior when scrolling using trackpad gestures or touchscreens, where scrolling in one dimension also causes the page to subtly scroll back and forth in the other. Note that this only affects certain websites and seems to be worse on certain devices. This is most likely related to our ongoing work to bring scrolling back to parity with Edge Legacy’s behavior, so if this behavior is undesirable, you can temporarily turn it off by disabling the edge://flags/#edge-experimental-scrolling flag.
  • There are some issues where users with multiple audio output devices sometimes don’t get any sound from Edge. In one case, Edge becomes muted in the Windows Volume Mixer and unmuting it fixes it. In another, restarting the browser fixes it.
As usual, you can manually update your browser by going to Settings -> About Microsoft Edge. Otherwise, it will just update in the background.
