MP3 Speed Changer Portable
ergir
MP3 Speed Changer 2.31 Portable
MP3 Speed Changer 2.31 Portable | 3.2 MB
Audio speed changer with batch processing and easy-to-use interface
MP3 Speed Changer enables you to speed up audio files (MP3, WMA, OGG) - podcasts, audiobooks without changing the pitch. Batch processing feature and easy-to-use user interface make MP3 Speed Changer valuable tool for audio listeners and authors who want to save time.
MP3 Speed Changer allows you to speed up your audio in seconds. All you have to do is select the files and new tempo. Files will be automatically speeded up and converted to MP3 so you can move them right to your
portable MP3 player or open in your favorite software MP3 player.
You can also save time with video files. M3SC enables you to extract the audio track, speed it up and save as MP3.
At the 150% tempo you save 20 minutes for every hour of audio material you listen to. Your mind can easily handle the faster tempo, since you can think far faster than anyone can naturally talk.
download
size- 3217 KB
http://rapidshare.com/files/106101160/MP3-Speed-Changer-2.31-Portable.exe
