D.o.c.t.o.r
- Credits
- 0
Multi Block Storage
32-разрядный менеджер буфера обмена для работы с часто повторяющимся текстом (редактирование, HTML-разметка, заполнение форм и т. д.). Поддерживает функцию "Drag & Drop", позволяет создавать собственные базы как в среде приложения, так и в простых текстовых редакторах.
Multi Block Storage is an office utility which allows you to create, use, and manage fragments of frequently-used text. This is very useful in word processing documents, filling out forms, HTML formatting, programming, and more. The application's toolbar, which looks like the taskbar, can contain an unlimited quantity of structured text fragments in the form of buttons and hotkey combinations can be assigned to each button. To paste text fragments to the desired area you simply need to click the corresponding button or press the assigned hotkeys. You also have access to all tools of adjustment and management through the context menu. Addition of a text fragment is also quite convenient - all you need to do is select it and press the hotkey combination or use the drag&drop function with your mouse. Furthermore, the application's bar can be automatically hidden to spare working space (autohide feature).
Features
- multi-lingual support
- wide functionality: extract fragments from any clipboard and/or Drag&Drop supporting applications, even some console applications;
- non-intrusive: convenient taskbar interface (Application Bar with autohide capability);
- interactive: organize fragments and see results immediately;
- wide compatibility: runs on any Win32 platform (9x, ME, NT, 2000, XP);
- small file size: fast download and installation, saves disk space thanks to its small application size;
- flexibility: select asked confirmations;
- easy-to-use: assign hotkeys for any of the application·s functions: fragment storing, fragment pasting, etc.;
- customizable: ajust delays before autohide bar appears and disappears, set size and position of autohide bar's activation area.
- powerful: macro expressions support allows you to specify date and time in your text fragments and others.
- safe: automatic data saving on each change and Recycle Bin feature.
Официальный сайт программы / Officail site:
Cкачать / Download:
Уже пролеченый Multi Block Storage версии 3.2 находится в прикреплённом файле
Features
Cкачать / Download:
