Orbada multi platform multi database management tool
murat turan
ORBADA is an excellent tool for database developers, SQL developers, DBA administrators, as well as for users who wish to broaden their knowledge and skills in SQL.
Advanced functionally and intuitive and clear graphical interface makes it easier to administer the database. By using JDBC libraries allows you to connect to multiple databases. Dedicated plug-ins for databases such as Oracle, SQLite, Firebird, HSQLDB, DerbyDB allow even better use of their possibilities. Well-rounded graphic interface that allows to perform simple tasks as well and advanced operations DBA too. A clear menu system and multiple tabs makes browsing, searching and modifying objects in a database easy for each user.
Drivers:
Apache Derby
CSV JDBC
DBF
Firebird
Firebird JSBC/ODBC
H2 Server
HSQLDB
JDBC ODBC Bridge
Microsoft SQL Server
My SQL Server
Oracle
Postgre SQL
SQLite
StelsCSV JDBC Driver
