PEGASYS Inc. (TMPGenc) Products
Soul
All In One PEGASYS Inc. Products - New Pack
TMPGEnc MPEG Editor v1.0.1.59
HIGH SPEED MPEG Editor !!!
TMPGEnc MPEG Editor is a greatly improved version of MPEG Tool (included in TMPGEnc Plus 2.5). It has been reworked into a full-featured software offering fast, precise and easy cut-editing. This is possible thanks to the Technical Wizard interface and the Smart Rendering function. As it is compatible with DVD-VR(VRO), you can load DVD-videos you have made in the past, edit and convert them to MPEGs.
TMPGEnc 3.0 XPress v3.0.4.24
TMPGEnc 3.0 XPress is a High quality Video encoder software, based on the famous "TMPGEnc Plus 2.5"... TMPGEnc 3.0 XPress natively supports source files in MPEG-1/2 format, unprotected DVD-Video VOB, Windows Media Video«, uncompressed AVI and QuickTime« files. Furthermore, the code has been optimized to take advantage of the Intel« Prescott« SSE-3 acceleration to output MPEG files with higher performance and without losing quality. Output format is no more limited to MPEG, TMPGEnc 3.0 XPress offers native interface for Windows Media Video«.
TMPGEnc Plus 2.524.63.181
TMPGEnc is famous for it's better quality comparing to current encoding software retail packages in market. If you are looking for MPEG encoder, you should try this before you spend some money for other encoding software.
TMPGEnc DVD Source Creator v2.1.3.8
Optimized MPEG-2 encoding mode for DVD video creation!
TMPGEnc is one of the best MPEG-1&2 encoder around the world, used among beginners and Professional users. "TMPGEnc DVD Source Creator" is based on TMPGEnc and developed for users to easily produce
MPEG-2 files for high quality DVD.
- New interface based on project wizard, it's easy-to-use
- Supports DV format (only type 2), AVI and MPEG-2 decoder
- Encodes multiple source files into a single MPEG file.
- 2 pass VBR encode engine provides high quality movie.
TMPGEnc DVD Author v1.6.26.73
The easiest way for DVD Authoring !!!
With TMPGEnc DVD Author you can change (author) your MPEG-1 / MPEG-2 files to DVD-Video structured files. Using high quality MPEG files made by TMPGEnc encoder (DVD Source Creator, Plus 2.5, 3.0 XPress) or captured by an MPEG capture device, it is possible to perform your own DVD authoring quick and easy. The output file structure (.ifo, VOB) can be burned to a DVD disc using the DVD writing tool, and thus you can create your own original DVDs.
Burning on "DVD+R Double Layer"...
TMPGEnc Sound Plug-in AC-3 v1.10
Thanks to it, it is possible to decode and encode in
Dolby® Digital (AC-3) 2ch audio with products that support the plug-in:
- TMPGEnc DVD Author (1.5 & 1.6)
- TMPGEnc 3.0 XPress
- TMPGEnc MPEG Editor.
More Info: http://www.pegasys-inc.com/en/product/index.html
Download (two parts)
Part 1 (28.3 MB)..._Как увидеть ссылки? | How to see hidden links?
and
Part 2 (25.7 MB)..._Как увидеть ссылки? | How to see hidden links?
И сейчас тоже самое. А хотелось бы!
Brodjaga, автор темы как-то написал, что на форумсе больше постить не будет. Он себя здесь разрекламировал, а потом написал: ''ищите меня по моему нику''. Если он объявится и обновит тему, я буду удивлён. Приятно удивлён...
TMPGEnc XPress 4.10.179
_http://download1.pegasys-inc.com/download_files/TE4XP-retail-4.1.0.179-install_EN.exe
все хорошо, только ключик просит... кто-нить может помочь?
TMPGEnc Xpress v3.3.8.117
11466KB
Download
_http://www.ware8.com/download.asp?id=1880&ware8=down1
_http://www.ware8.com/download.asp?id=1880&ware8=down2
_http://www.ware8.com/download.asp?id=1880&ware8=down3
Crack ARN
_http://www1.enfull.com/download5.asp?id=1880&crack=crack1
_http://www1.enfull.com/download5.asp?id=1880&crack=crack2
_http://www1.enfull.com/download5.asp?id=1880&crack=crack3
как добраться до TMPGEnc MPEG Autor v2.0 и TMPGEnc MPEG Editor v2,0 retail версий?
замечательно.. я добрался до TMPGEnc MPEG Autor v2.0 ретиал... где взять крак?!
Кто знает, где взять лекарство к TMPGEnc Sound Plug-in AC-3 Ver.1.40?
Реакции: piro
Pegasys Inc TMPGEnc DVD Author 3 with DivX Authoring Retail ver. 3.0.5.149
Господа МОДЕРАТОРЫ/АДМИНИСТРАТОРЫ, уберите плиз из названия темы слова All In One (( а ещё лучше переименовать её в PEGASYS Inc. (TMPGenc) Products - сильно упростит жизнь тем, кто пользуется поиском по форуму)
Реакции: Msha
TMPGEnc DVD Author 3.0.5.149
Программа для создания и прожига DVD дисков из MPEG1 и MPEG2 видео файлов.
TMPGEnc DVD Author 3 with DivX® Authoring offers many new features and some terrific advancements over its predecessors. It is the ultimate all-in-one DVD authoring solution for any video enthusiast, whether you're a beginner or experienced videographer. Enjoy new features such as DivX® authoring, HDV capture, more import formats, up to two subtitle streams, and more!
Main features
• Officially licensed DivX® video software product
• Produce high-quality DVD and DivX® video
• Import most popular video formats
• Capture video directly from your DV or HDV camcorder
• Add up to two subtitle streams
• Create your own custom menus or use ready-made templates
• Perform precise frame cut-edits with Smart Rendering
• Shrink (transcode) your video to fit onto different media
• Multi core CPU support
• Dolby Digital stereo output
more info
Download 49 MB
Addon
Mirror
