Pointstone System Cleaner v5.56.191 Portable
ergir
System Cleaner takes care of all the common PC headaches that slow your system down and puts your data at risk from disk failure. It also takes care of many of the of the PC problems that other so-called tune-up programs ignore.
System Cleaner also includes a comprehensive "secrets eraser" that scrubs all of your computer and internet activity files and removes every last trace of where you have been and what you did while you were there.
Just look at everything that System Cleaner does:
* Restores your hard drive's performance
* Fixes system errors that slow your PC down and cause it to crash
* Speeds up your PC's execution of software programs
* Removes space-wasting temporary files and other unnecessary disk clutter
* Tunes up and optimizes the Windows Registry
* Erases all evidence of your computer and internet activity
* Makes your PC boot faster
* Makes your PC shutdown faster
* Fine-tunes all important Windows settings
download
size- 3702 KB
http://rapidshare.com/files/81295223/Pointstone-System-Cleaner-v5.56.191.exe
