Unattended | Portable Belltech Business Card Designer Pro 5.2.3 | 12 MB | RS
Create your own business cards and print on your own printer right now! Design your stunning business cards easily. Belltech Business Card Designer Pro, a feature-rich professional quality business card software, helps you create amazing cards in a matter of minutes and print them right-away -- on your own printer, on card stocks from Avery, Sigel, Herma, Formtec, DECAdry etc. Want to see how your business card may look like? See some samples of business cards designed using this card creator.
Product Highlights:
* Quick and Easy Design: Select and draw shapes and text. Resize, tilt, change color, fill with gradient color or do anything with your design elements.
* Use templates and graphics: Don't know how to start the layout of your card? Use our card templates, background and clip-arts to start with easily. Simple to use yet so powerful!
* Convenient Design tools: Can draw rectangle/triangle/circle or any freehand lines and shapes.
* Stunning Background: Use the supplied backgrounds or use your own. Anything is possible and is easy.
* Use Color blends: This is a unique feature of this business card software. You can now have a color blend the way you want, the control is in your hand. Remember, this is not a static background image, but a filled shape whose color-blend and texture you control completely." Possibilities are endless!
* Use your own clip-arts, logo, photos: We supply you with many graphics that you can use, but don't think that it is all you can use. Get your own picture, logos, clip-art and design the perfect card you want.
* Supports any printing papers: Supports all standard business card papers from Avery and other suppliers.
* Choose any card size: With version 1.2 and above you can choose any size from 1 X 1 inch to 5 X 5 inch. The choice is yours. The US standard is 3.5 X 2 inch or 2 X 3.5 inch.
* Customize printing: Want to print 1 card or 5 card? You decide and watch the printing!!.
* Save as image: You can save your work as bmp, jpg, gif, png image and take it to your favorite print-shop to have professional printing done.
System Requirements:
-Windows 98/ME/2000/2003/NT/XP/Vista
-64 MB of RAM and less than 30 MB of hard drive space.
UNATTENDED
http://rapidshare.com/files/238966541/Belltech_Business__Card__Designer_Pro.v5.2.3_Unattended.Kat__305_l__305_ms__305_z.exe
PORTABLE
http://rapidshare.com/files/238969411/Belltech_Business__Card__Designer_Pro.v5.2.3_Portable.exe
