Portable Universal Viewer (ATViewer) Pro
ergir
Universal Viewer (ATViewer) Pro 3.0.0.0 Portable
Universal Viewer (ATViewer) is an advanced file viewer with wide range of formats supported. Implemented view modes and corresponding file formats are:
Text, Binary, Hex, Unicode: any files, of unlimited size (even 4Gb+ sizes are allowed)
RTF, UTF-8: RTF and UTF-8 encoded texts
Image: all general graphics formats: BMP JPG GIF PNG TGA TIFF... plus all formats supported by IrfanView/XnView external viewers
Multimedia: all formats supported by MS Windows Media Player: AVI MPG WMV MP3...
Internet: all formats supported by MS Internet Explorer: HTML XML DOC XLS...
Plugins: all formats supported by Total Commander Lister plugins
Version 3.0.0 (25 Jan 2008):
* Note for Pro version: License type is shown in About box. If you see wrong license type, please write to support address to update your key.
* Changed: "Regular expression" search option is now in Pro version only.
* Added: Support for folder plugins such as VisualDirSize. Notes:
o Free version: to activate such plugins you must pass the folder name in command line;
o Pro version: to activate such plugins you can also click a folder in Navigation panel Listview;
o most of file commands are disabled for such plugins.
* Added: Find features:
o "Find" dialog reworked, added "Origin" option.
o "Find previous" command (Note: only for text modes and not for RegEx).
o When "Hex string" search option is changed, text is automatically encoded/decoded.
* Added: Options dialog reworked.
* Added: Plugin dialog: Button to edit plugin ini file.
* Added: On image loading errors UV doesn't show messagebox, but instead shows error text in image corner.
* Added: Options for image label colors.
* Added: Command line parameter "/Mode".
* Removed: Multimedia mode "MCI".
* Removed: Hidden option "TextVariableScrollbar".
* Fixed: Find error on changing view mode.
* Fixed: Text mode: Trailing spaces showing on word wrap.
* Fixed: Plugins mode: Crash with Syn, Hpg_Ed.
download
size- 1455 KB
http://rapidshare.com/files/87283058/Universal-Viewer-_ATViewer_-Pro-3.0.0.0-Portable.exe
note-it writes trial but its full​
Universal Viewer 6.4.5.1 Pro Plugins Portable
by Boomer
Universal Viewer - это универсальный просмотрщик любых файлов: текстовых, изображений, двоичных, шестнадцатеричных, мультимедийных, в форматах для браузеров. По своей функциональности он хоть и похож на Total Commander Lister, но значительно мощнее его по своим возможностям.
Программа выпускается в двух редакциях: Free (бесплатная) и Pro. Редакция Pro отличается от бесплатной поддержкой файлов Word, Excel (в том числе и DOCX, XLSX), предустановленным плагином PDF, новым мультимедиа плеером, поддерживающим 170 форматов, поддержкой файлов RAW и сложных файлов RTF, содержащих таблицы и изображения.
Файлы и форматы, с которыми работает программа:
- все основные графические форматы: JPG, BMP, ICO, GIF, PNG, WMF, TIFF, PSD и др., более 40 форматов. Кроме того поддерживаются RAW-изображения камер 400+;
- все основные media-форматы: AVI, MPG, WMV, MP3, MP4, FLV, MKV и др., свыше 170 форматов;
- форматы MS Office Word: DOC, DOCX;
- форматы MS Office Excel: XLS, XLSX;
- форматы Adobe PDF, DJVU, XPS, CBR, CBZ;
- Rich Text format (RTF);
- все типы файлов, поддерживаемых MS Internet Explorer: HTML, XML, MHT и пр.
Все файлы других форматов рассматриваются в качестве текстовых. Размер файла не ограничен (могут быть показаны даже файлы размером более 4 Гбайт). Поддерживаются все основные кодировки текстовых файлов, включая Unicode/UTF-8.
Особенностью программы является то, что для просмотра Word/Excel/PDF-файлов не требуется наличия установленных соответствующих пакетов MS Office и Adobe Reader (или других программ чтения PDF-файлов). И также нет необходимости во внешних кодеках при просмотре мультмедиа-файлов.
В последней версии разработчик наряду с обычным предоставляет и портативный вариант программы. Также отпала необходимость в обязательном наличии на компьютере установленного .NET Framework. Изменился и порядок регистрации программы: вместо online-активации теперь используется серийный ключ.
Название и редакция: Universal Viewer Pro
Версия и сборка: 6.4.5.1 Plugins Portable
Операц. система: Windows All
Разработчик: Алексей Торгашин
Год: 2012
Автор сборки: Boomer
Интерфейс: английский, русский
Лекарство: вшито
Скачать бесплатно "Universal Viewer 6.4.5.1 Pro Plugins Portable by Boomer"
