Power AutoPlay Menu Creator Pro (все версии)
Vitalik
В тени
Power AutoPlay Menu Creator Pro v7.7.120507D
Power AutoPlay Menu Creator Professional - мощный пакет для создания autorun-меню, которое появляется автоматически после вставки CD/DVD в привод. Не требует знания программирования и легко осваивается. C ее помощью вы можете легко и просто создавать неповторимые практически профессиональные каталоги дисков, увлекательные презентации, фотоальбомы и качественные слайдшоу...
Power AutoPlay Menu Creator Features
* Just thinking, no programming.
* Rapid development environment to create autoplay menus quickly.
* Powerful WYSIWYG designer, easy to use without learning.
* Easy testing without burning on disc.
* Comes with many templates (Over 27).
* Protect menus from being modified by others with password.
* Create projects from templates, (It comes with a large number of templates and project assistants that enable anyone to create professional results in no time at all.)
* Support multi-page window, shaped window and full screen window.
* Interactive Objects
* reate drop down menu bar for pages like most standard windows to make your page more professional.
* Hide menus in system tray (Action).
* Input text box to check user entry and do action
* Internal slide show support.
* Muti-Action (There are unlimited actions available for each object including running external programs and opening documents,
pointing web browser to specific web page, displaying text messages, navigating another Page, etc.)
* Many cool controls.
* Send Email Action
* Shutdown Actions
* Make CD Business Cards
* Custom Windows Shapes
* Publish to Web/Email Executable
* Open Website Windows
* Shutdown Splash Image
* Play Multimedia Files
* Display Adobe Acrobat PDF Documents
* Option button control.
* Hot spot support in your menu
* Page have action when Loaded
* Sample Projects
* Internal slide show (by Action)
* Explorer CD or folder on CD (Actions)
* Computer Restart & Shutdown (Actions)
* Timer control to do actions after time
* Resize window in run time (Action)
* Many kinds of actions such as launching application, open document, etc.
* Many controls.
* Embed Flash Player, Internet Explorer in menus.
* Eject CD & Eject CD and exit (Action)
* Copy file, folder, or all CD form CD to hard drive (Action)
* Text and graphic comments while moving cursor over controls.
* Support MP3/WAV/MID/WMA files for background music.
* Play movie files & sound files in player tool (Actions)
* Show splash screen and end screen
* Play sound when mouse over buttons or click
* Customize disc icon and mouse cursors.
* support animated GIF
* Many styles of button
* Play background music (play list) looped
* File list tool (to display more files) in your menu
* Fast and Fun to Use!
* make your page more professional.
* Add advanced Label With full Gradient Color.
* Add expiration CD Date.
* Custom Button control.
* Jump to next page.
* Jump to Previous page.
* Jump to Last page.
* Jump to first page.
* Publish Project Menu.
* Always On Top Action
* Pack your project in one exe file (self-extractor)
* And much more.
System Requirement:
* Operation System: Windows 98/ME/NT4/2000/XP/2003/Vista
* 22 MB free hard drive space
* Pentium 120 MHz
* Memory: 32 MB RAM or above
* Video card set to 16 bit color or greater
home Как увидеть ссылки? | How to see hidden links?
7575 KB
пробуем лекарство...
для Power AutoPlay Menu Creator Pro v7.7.120507D
278 KB
Power AutoPlay Menu Creator Professional v7.3 build 031106
7.3 MB
пароль:_http://dumpz.ru
Сама программа регистрируется, но создает готовые проекты только ДЕМО, со всеми вытекающими аттрибутами: Это Демо версия - зарегистрируйтесь!!! - и так далее. Применял активацию полностью - как написано в Readme. Увы :(( Может у кого есть более реальная аптечка?
Товарищщщщ Vitalik пороверять надо что выкладываешь!!!:) тем более leserg73 был прав полностью!!!
johnydj,
Посмотри сколько прог я выкладываю... И если каждую я буду проверять досконально, мне жизни не хватит......
278 KB
