Power Software Wiper Portable
ergir
Power Software Wiper 5.0.1.2 Portable
Power Software Wiper is a replacement for the standard Windows Add/Remove Software dialog. It loads fast and offers some additional features to remove leftover files and registry entries, as well as a forced uninstall mode for programs that did not come with a common uninstall tool.
The standard Add/Remove program can't uninstall applications completely; it often leaves broken registry keys, unnecessary files on the hard disk. The more junk files your computer has, the slower it runs. Power Software Wiper can wipe off all the junk files completely in seconds. It offers a more user-friendly way to remove unneeded applications and to improve your computer's efficiency.
Removing files from your system is a lot harder than installing them. Even though when you uninstall a program with its own uninstaller it may leave leftovers behind. (Like empty directories, log files, registry entries etc.) Power Software Wiper is the program that enables you to safely remove all unwanted applications and files. It displays details of installed applications, which allows you to view all details of a certain application installed on your computer, or to uninstall a certain application quickly and completely.
download
size- 2513 KB
http://rapidshare.com/files/90189373/Power-Software-Wiper-5.0.1.2-Portable.exe
