G
Gennadiy
Search Engine Builder Professional v2.23
Программа создает одну HTML страницу и JavaScript файл, содержащие поисковый скрипт для Вашего сайта.
Build a search engine for your website to enable your site visitors to search your whole site. The site search script can be ASP, PHP, Java Scrip, etc. The appearance and functional of the search engine are fully configurable.
What is Search Engine Builder Professional?
Many visitors are usually interested in specific information of your website. If they take too much time to find what they want, they will go to other sites instead.
Search Engine Builder Professional is specifically designed to solve this problem. It indexes your entire website quickly and generates an efficient search engine. It makes it easier for your visitors to find things on your website and gives it a more professional appearance.
It's easy to build a search engine with this tool. Just click a few buttons and no need to write any tedious spider code.
This pro version is specifically designed to deal with large site that have thousands and millions of pages. And it includes all functions and features of standard version.
Your site visitors can find what they want easily and rapidly.
A site search box makes your site more professional .
Page templates enable you to build a search engine with various attractive and functional search pages.
The style, font and color of the output search result are fully configurable.
Enables you to index and search PDF, DOC, XLS, PPT, RTF and many other file types.
Enables you to build a search engine for searching local files, CD-ROM etc.
It's easy to work with multiple websites.
Search Engine Builder Pro includes all functions and features of standard version.
Search Engine Builder Pro enables you to index and search large site with thousands and millions pages.
Pro version generates site search script as ASP, PHP, Java Script etc..
Easy to install to website needn't to config web server.
Registered users receive FREE upgrades and technical support for life.
ОФФСАЙТ.
http://www.aleadsoft.com/search-engine-builder-pro/index.php
КАЧАТЬ.
http://www.aleadsoft.com/SearchEngineBuilderPro.exe
кейген
ОФФСАЙТ.
КАЧАТЬ.
кейген
