SWF Lock And Load v1.206
SWF Lock And Load - Программа для создания красивых анимированных флэш-прелоадов (индикаторов загрузки и т.д.)...
WF, Lock & Load is an extremely easy program to create animated Flash Preloaders in seconds!
SWF L&L is the best purchase I've made in months - one hell of a program! Lock & Load is truly the little engine that can.-Jay Huddy, satisfied user
Features
Output Macromedia Flash movie files (SWF). Over 97% of all browsers already have the Flash Player installed, so you won't have to worry about your audience being able to view your preloader.
Choose from over 100 graphical prealoder templates!
Preload your SWF files externally, or merge in the Preloader to create a single file.
Create "Smart Preloaders" which will attempt to preload enough for smooth playback based on the users connection speed.
Add custom feedback messages showing current statistics such as percentage, bytes loaded, and frames loaded.
Save project files so you can save your work to allow you to make changes to an existing prelaoder over time.
No fees are required for the Macromedia Flash file format, so you can create unlimited royalty free preloaders.
Add preloaders to slide shows created with SWF 'n Slide.
Скачать / Download SWF Lock And Load v1.206 (Размер\Size: 1527 Kb):
Keygen для\for SWF Lock And Load v1.206:
