Search Engine Studio v3.0.2
Search Engine Studio позволяет очень быстро и без особого труда создать поисковую систему по веб-сайту или по содержанию компакт-диска (в т.ч. DVD). Работу очень облечает пошаговый "Мастер", внешний вид поисковой системы полностью настраивается, имеется настраиваемое ранжирование результатов поиска. Загрузка созданного поисковика на сервер происходит автоматически. Работает быстро - как сама программа, так и созданная ей поисковая система.
Creating a search engine for your web site does not have to be difficult! With Search Engine Studio within a few minutes you can create a full-text search engine for your web site (works with any existing hosting) as a CGI or PHP script (or Java servlet), or you can even create an offline search engine for a CD-ROM / DVD distribution.
The difference between Search Engine Studio and other search engine generators is that it uses its own highly optimized database engine so there is absolutely no installation required on the server. All you need to do is follow a few easy steps of the assistant to have the program automatically index your website and then upload the required files to your server. Everything the search engine needs will be located on YOUR server without any references to other websites to ensure best possible performance. The search results will not display any ads or other unwanted content and for the first time you can FULLY customize the displayed result page appearance.
Search Engine Studio is based on SiteXpert(TM) technology which for the past 7 years has been helping thousands of web developers create their search engines and site navigation solutions.
Оф.сайт:
программа:
кейген:
