ACD Systems ACDSee Photo Manager & ACDSee Pro (все версии)
ACDSee PowerPack 7.0
What's New?
Acquire, organize, view and manage your images faster than ever—way faster.
Save time using more batch image functions than you'll find in any other product.
Share your photos instantly using SendPix, ACD's free online image sharing, now with mobile phone support.
Compare similar images. Use ACDSee 7's side-by-side Image Compare feature to pick out the best shot.
Use the Curves tool to correct exposure.Work effortlessly with multiple high-resolution images at the same time.
Examine your images in their original RAW formats.
ACDSee supports Canon, Nikon, Fujifilm, Olympus,Kodak, Minolta and other major camera brands.
Use the Create Disc Wizard to simultaneously burn image files to CD/DVD and create thumbnails of your offline CD.
Publish your images to TiVo?'s Digital Photo Viewer and bring the digital experience into the living room.
Expand your organizing and editing capabilities with more tools in the improved Image Basket.
View all of your photos at once in the Image Well.
View your folder contents in the Thumbs + Details mode, and specify which information to display.
Optimize your workflow using the Context Sensitive Toolbar.
Create PDF and Flash slide shows.
Manage your images even better in ACDSee 7's improved Organize pane.
Take advantage of ACDSee's support for MPV and HighMAT.
View, browse and convert images in the JPEG 2000 format.
Copy database information to and from your EXIF data.
Maintain your collection with enhanced database tools.
*Plus, automatically synchronize folders using the PowerPack version of ACDSee.
ACD Photo Editor3
Fix common problems such as light levels, red-eye and rotation using the simple Photo Correction Wizard.
Exposure warning indicators help you identify potential problems.
Advanced image editing tools.
Exposure warning indicators.
A Curves tool that allows you to correct exposure.
Professional color management using ICM 2.0 and ICC color profiles.
ACD FotoSlate 3
Print popular photo sizes, such as 4x6, and popular page sizes such as Letter, or pages in any size you choose.
Create calendars, greeting cards and CD covers from your favorite photos.
Create contact sheets in seconds using the Contact Sheet Wizard.
Get crisp prints from grainy, low resolution photos (such as those from email and the Web) with the click of a button, thanks to FotoSlate's unique Clear IQZ resampling.
Save paper with the Paper Saver Wizard that automatically fits as many pictures as possible on one page.
Frame your pictures before printing - choose from a number of beautiful frame designs.
Stylize your pictures by 'cutting' them into shapes like ovals and adding drop shadows.
Personalize the design of pages as you add photos, using the Page Designer.
Include camera metadata or file information automatically in prints.
Ensure accurate color with EXIF Print support and ICM 2.0 and ICC color profiles.
качать.
_http://files.acdsystems.com/english/downloads/acdsite/acdseepowerpack.exe
_http://dlb.pchome.net/multimedia/viewer/acdseepowerpack70.exe
_http://dl96590.pchome.net/multimedia/viewer/acdseepowerpack70.exe
19.1 мг
качать ACDSee 7.0 Standard .
_http://dlb.pchome.net/multimedia/viewer/acdsee70.exe
_http://dl96590.pchome.net/multimedia/viewer/acdsee70.exe
_ftp://dlb.pchome.net/multimedia/viewer/acdsee70.exe
14.7 мг
кряк.
Сорри, за серийники, исправимся!
А тогда скажите сейчас в сети появился keygen. А при инсталяции можно выбрать Trial (поле серийника неактивно) или Full (вводим серийник). А нафига тогда dll заменять, если вводим валидный серийник???
Вот keygen для ACDSee 7.0 от CORE.
Активировать через интернет.
Успехов
Domino
Этот "валидный" серийник кроме тебя вводит ещё дофига народу.
Встречаются случаи, когда разработчик ПО проверяет серийники, и если этот разработчик узнаёт, что этим серийником пользуется несколько пользователей, то ПО начинает глючить и т. д. А DLL по идее должен обезопасить нас от подобных глюков (но это к сожалению не всегда)
shefanovski
Воспользовался я кейгеном от CORE. Активировался. Все нормально. Только у меня кейген почему-то в три раза меньше
alba сказал(а):
shefanovski
Просто там еще и файлик с рекламой возможностей программистов CORE. Я его не стал удалять, так как не я создатель и не мне редактировать zip.
Вот и все.
Сами keygens абсолютно идентичны.
ACDSee.7.0.43.PowerPack.Retail
Залил комплект ACDSee.7.0.43.PowerPack.Retail к нам.
Вес комплекта 17.5 мб
Внутри если инсталяционный файл, кейген от CORE и патч от diGERATi
Я ставил программу и регистрировал ее (активировал через интернет) с помощью кейгена- все работает. Но для активации нужно быть в инете, в обратном случае (у кого нет инета) поможет патч .
Скачать комплект можно отсюда:
Как увидеть ссылки? | How to see hidden links?.[by.KiN_www.netz.ru].rar
Порядок активации программы кейгеном:
1. Сгенерируйте серийник
2. При начале устанки программы, выберите полную установку (FULL) и введите сгенерированный серийник.
3. После установки запустите программу и активируйте ее через интерент, но после активации не регистрируйте ее, когда вам это предложит сама программа.
Порядок регистрации программы патчем, написанно в текстовом файле в папке патча.
Fixed Keygen from CORE
Кейген немного доработали и пофиксили...
Все равно не работает =))
[ADDED=???]1096690085[/ADDED]
Упсс... сорри заработал... только клычик то раза с 5-го подошел....
И кстати к этой версии русика нет ?
да уж русик бы не помешал ))) даешь русик
нужно пользоваться тем, что выложил diSmiSS, тогда с первого :)
Добрый день всем.
Не знаю - может идея и дикая ...но у меня появилось предположение, что Программа при инсталяциии отслеживает использование Key-Gen-а (до или в процессе установки)и не принимает ключи сгенерированные Key-Gen-и на машине, где присходит установка
Почему так думаю:
- долго и нудно ...почти 2 часа пробовал номера от Key-Gen-ов скачаных с разных адресов, в том числе и по ссылке от " diSmiSS"
- при второй и далее попытках в генерируемых номерах уже не все символы отражаются, т.е. квадратик вместо тире или символа или не хватает тире (т.е. первый номер отличается по виду от следующих)
- ПОТОМ додумался до этой идеи
- скопировал Key-Gen от "diSmiSS" на другую машину
- там начёлкал номеров и !!!первый же прошёл и дальше всё нормально установилось и активировалось
Может это предположение и за уши притянуто ...но ведь запуск любой программы, даже самораспаковывающегося архива вносит изменения в ОС - это можно с помощью любой программы-UnInstall увидеть.
По крайней мере до следующей перезагрузки изменения сохраняются.
Так, что товарищи - которые старшие товарищи ...подумайте, может и в правду мне что дельное в голову пришло.
Holod-71, мысль интересная, вполне возможно, что так оно и есть. но только ведь в инструкции сказано сгенерить - а потом ставить.
если твои опасения оправданы, то, может стоит написать:
1) сгенерить, сохранить номерок (номерки).
2)выйти из кейкена. может, и перезагрузиться?
3) ставить
