G
Gennadiy
Acoustica CD DVD Label Maker v.3.03
программа для создания обложек компакт-дисков.
В базе программы имеется пакет готовых шаблонов, плюс широкие возможности для изготовления ваших индивидуальных этикеток.
есть возможностью импорта информации о трэках из WinAmp, Easy CD Creator и других программ, создающих плейлисты и много другого.
Create your own CD, DVD, and jewel-case labels. Let the wizard create labels for you in a hurry with minimum fuss, or man the controls yourself to get every detail of text, fonts, and images just the way your muse demands. Use the built-in art for holidays, events, and just generally good labels, or import your own pictures with the image-search feature and thumbnail views. Automatically import your song information from programs including Acoustica MP3 CD Burner, Winamp, Nero, iTunes, and Easy CD Creator. Features include circular and spiral text; a variety of new ways to lay out tracks listings, including multiple columns, multiple tracks per line, text that wraps on both sides of the CD hole, and spiral text; support for 99% of paper stocks, plus support for direct-to-CD and EZ/CD Print; and automatic importing of iTunes playlists that were exported in either XML or TXT formats. Updates in version 2.16 include MP3 CD support, better track formatting options and bug
качать:
программа:
кейген:
Дугие программы от Acoustica:
качать:
программа:
кейген:
