CHANGES AND ADDITIONAL NEW FEATURES
o Simplified the so-called "Ghost" session:
1) MDaemon no longer requires a separate "Ghost" program manager icon
2) The Ghost term was dropped. Configuration Sessions are now called
Configuration Sessions.
3) Launching MDaemon for the first time starts all the mail services
while any subsequent launch either starts or brings to the fore the
Configuration Session.
o PocketPC theme fixes & changes:
1) [4761] Changed navigation to be text links instead of images. This should
improve load speeds and reduce bandwidth usage
2) [4836] Changed .PocketPC login to not force the .PocketPC theme if the
user doesn't pass "&Theme=.PocketPC" in the URL
3) [4982] If a non-Pocket IE browser uses the .PocketPC theme they will be
allowed to switch themes (this is useful for desktop browsers that
accidentally get changed to .PocketPC theme)
4) [4219] fixed the delete calendar events bug that prevented calendar
events from being deleted.
o [5106] Added MDSpamD "debug logging" (which is disabled by default):
1) Added MDSpamD tab to the main MDaemon UI.
2) Added switch to logging options to enable MDSpamD logging - a warning
though, this is a performance drain.
3) Added same switch to MDSpamD tab in Spam Filter UI.
4) Added an MDSpamD log file which tracks all this logging - another warn-
ing, this file could get big fast.
Known limitation: When MDaemon runs as a service and user credentials are
provided MDaemon will not be able to communciate with MDSpamD for logging
purposes and no logging will take place.
o [5119] Added "Show Window" option to MDSpamD properties in the Spam Filter.
When this is enabled the output from MDSpamD is piped to its external process
window rather than MDaemon's internal UI and logging system. This will avoid
the performance drain associated with piping MDSpamD output into MDaemon itself.
However, there will be no log file created. This option can not be used in
combination with the MDSpamD internal UI and logging option.
o [4434] Moved the installer backup option from the "directory selection"
page to the "start installation" page. This is to solve a problem whereby
many people were thinking the installation directory was actually the
backup directory and so they were changing it. The result was an install-
ation that did not work properly.
o [4554] Added option to reverse lookups to exempt authenticated sessions
from PTR lookups on the connecting IP. When this switch is enabled the
PTR lookup on the connecting IP is deferred until after the MAIL command
in order to determine whether the connection used authentication or not.
o [4662] You can now enter ZERO into the retry queue configuration for the
number of days to retry delivering mail. After the first retry, the message
will be bounced back.
o [5067] The option to count sub-folders when applying quota restrictions
has been disabled by default. This setting is in Misc. Options|Misc if
you want to check and make sure it is set to your expectation.
o [5155] Reorganized the tab layout in the main GUI to group things together
in a more organized way. The security related items are now in a Security
tab and the OC and WC items are in the Mail tab.
o [5156] Added SyncML log tab to GUI. This just mirrors the SyncML log file.
o [5121] Changed work file copy method to prevent .cf files from going missing
at times.
o [5120] Added option to Misc Options|GUI to save the state of the stat window
root node counters across reboots.
o [5128] The DNS-BL engine was changed to skip the X _most recent_ Received headers
rather than the X _oldest_ Received headers. It doesn't seem to make much sense
to skip the oldest Received headers. The idea is you want to skip the newest
Received headers because those stamps would be from the hops closest to you which
you might trust (especially your ISP in the case of DomainPOP/MultiPOP mail). Also,
the default number of Received headers to skip for SMTP collected mail was changed
to 0 rather than 1. The DNS-BL GUI was updated.
o [5139] Moved several CF and AV related .dat files out of MDaemon's resource file
and into disk files that the installer will pick up and place in the APP folder.
o [5068] Constantly hitting the disk to check user quotas has been identified
as a significant performance drain. So, the results of these quota checks
are now cached in QUOTACOUNTS.DAT. MDaemon will maintain and police this
file. If you want to clear the cached quota value for an account add that
account's email address to a CLEARQUOTACOUNTS.SEM file and place it in the
APP folder.
o [5070] Added a "Statistics" tab to the main UI. This contain the same
summary report that is generated by other means (see elsewhere in this
document). This report is not updated in real-time but it should refresh with
current content every minute or so. It is possible to alter the text in
this tab because I don't know how to prevent that however it could be useful I
suppose.
If you don't like the font I used you can customize it in MDaemon.ini:
[ReportWindow]
DefFontFace=Courier New
DefFontHeigh=15
DefFontWidth=7
o The WebAdmin configuration dialog has lost the domain and language select-
ion controls. WebAdmin dymanically detects the language that the user
needs so these controls were irrelevant.
o [5071] Added quarantine queue to the queue list in stats window.
o [5073] Added right-click option to session window to put IP of selected
entries on the dynamic screen. Nothing will be done if dynamic screening is
disabled and this feature can not add trusted or local IPs.
o [5069] Right-clicking on a root node in stats window gives a "reset root
node counts" option which zeros all the root node counters (this is
necessary because they all inter-relate for proper calculations).
o [5075] Removed option to "authenticate list posts using FROM header" from
Misc Options. This will always take place. MDaemon will also verify list
posters using the SMTP envelope unless you set this switch in the
MDaemon.ini file:
[Special]
EnvelopeListCheck=No (default Yes)
o [5096] WorldClient's mail check has been optimized to defer loading new
messages until a folder is actually opened. Previously, checking for
mail would load all new messages in all folders. This should reduce log
in times.
o [5125] Updated DKIM to version 0.5 of the specification.
o [4969] Added DKIM signing option to include z= (copied headers) in
signatures.
o [4956] The DKIM verifier no longer queries for or honors DKIM SSP records
by default. You can re-enable this via a new switch located on the DK/DKIM
verification UI. SSP is being disabled by default in preparation for SSP
changes which are coming thanks to the work being done in the IETF right
now. When enabled, MDaemon's DKIM verifier processes SSP records according
to
Как увидеть ссылки? | How to see hidden links?.
o [4918] WorldClient's contacts now support a name prefix and suffix. These
fields are synchronized with the Outlook Connector and SyncML.
o The FORGED_MUA_OUTLOOK rule has been reenabled in 80_MDaemon_scores.cf.
o Added scroll-bar to folder selection in Account filter editor.
o MDaemon will log an error code into the System log anytime a process fails
to start or fails to start as a specified user. This will allow us to try
and discover why these failures happen for some sites.
o The Content Filter "Administrators" tab has been renamed "Recipients" since
this is just a list of email addresses that receive Content Filter
notification messages.
o Previously, messages over 50K were not put through the spam filter. Now the
default is 200K.
o Slightly changed text on Account Forwarding, Gateway Forwarding, and Setup|
Primary Domain|Delivery UI to state how to specify host name values.
o The installer will delete old 80_MDaemon_surbl.cf and 90_MDaemon_surbl.cf
files.
o Slight textual changes to Spam Filter Bayesian tab.
o Made slight GUI change to mailing list notifications tab.
o [4924] IP and Host screening will never block local or trusted IPs.
o [4892] Several changes were made to the anti-relay logic and UI. The UI was
changed to better reflect how the options actually work and interact. For
example, the options to verify whether local accounts exist when given in an
SMTP MAIL or RCPT command now operate on their own - they no longer depend
on what the anti-relay setting says. Second, a new option is available
which will allow you to control whether messages sent from trusted IPs or
hosts should be relayed. In previous versions this was always allowed but
now it has to be specifically enabled.
o [4928] Removed update checking code from MDaemon.exe and put it all into
MDUpdater.exe (previously some of it was in one place and the rest in the
other place).
o [4926] Messages submitted to MDaemon from the same computer as MDaemon will
no longer be spam filtered by default. This mainly impacts WorldClient
since mail submitted by WorldClient to MDaemon for delivery always takes
place on the same computer. You can disable this behavior by setting the
following switch in the CFilter.ini file:
[SpamFilter]
SkipLocalLoopback=No (default Yes)
o [2237] Added an option to the Content Filter which allows you to scan the
content of zipped attachments looking for restricted files. This option
appears on a slightly redesigned "Attachments" tab within the Content
Filter. In addition, any rule which triggers based on a file name match
will trigger if the file is found within a zipped attachment.
o [4859] Added an option to Misc Options|Headers and Setup|Primary Domain to
always use the FQDN value when creating Received header stamps. By default,
MDaemon uses the domain value associated with the connecting IP or
recipient(s).
o Added four INI values for that can be placed in WorldClient's Domains.ini
or User.ini files that will speed up the HTML compose component's load time
by disabling specific plugins:
DisableComposeCharacterMap=Yes
DisableComposeListType=Yes
DisableComposeStylist=Yes
DisableComposeTableOperations=Yes
These values default to 'No' so that the compose view will load as people
are used to in the 9.0 series.
o [4921] Added two User.ini values that will set a minimum width for the left
pane in the WorldClient LookOut theme. The possible values are:
MinLeftPaneWidth=[Yes/No]
MinLeftPaneWidthValue=[1-350]
o [4965] Improved the stats report and added a "Statistics" node to the Stats
window. Also, at midnight each night, the postmaster and all content filter
administrator users will receive the report via email. If this isn't desired
the following MDaemon.ini switch can disable it:
[Special]
SendStatsReport=No (default Yes)
This is the same report that is generated when MDaemon receives the Status
command via qualified email.
o [3639] added separate logging option to enable/disable MultiPOP log
o [4865] added separate logging option to enable/disable DomainPOP log
o [4864] changed UI references to "forward to this host" to "forward to this
domain" since MX record processing is being performed. Also added some UI
text explaining how one can still achieve a "forward to this host" A-record
only delivery.
o [4794] removed greylist file cleanup during MDaemon startup
o [4798] updated/added warning text when enabling PTR/HELO refusal options.
o [4839] added "Delete Message" IMAP filter rule action
o [4845] added "Strip X-Spam-Flag header" option to Misc. Options|Headers UI.
If you want to strip existing X-Spam-Flag headers from messages you will
Need to set this switch. The old MDaemon.ini hack to do this has been
deprecated.
o [4795] The DNS options "Immediately return mail when DNS says A record host
not found" and the similar option for MX records have been replaced by a
single option that will return (bounce) messages when there are no MX _or_ A
records for a domain. The GUI was appropriately updated. The option is
enabled by default.
o [4919] Wednesdy logs are now spelled correctly - Wednesday.
o [4927] Updated MDSpamD to use SA 3.15.
o [4933] MD will police APP folder for RAS dll and delete it if there (to
prevent a possible exploit).
o [4939] The name of the MDaemon service is now always "MDaemon" and can not
be changed by users. The service editor in the UI was updated accordingly.
Also the Network Resource Access text was altered slightly.
o [4846] Webadmin SSL port will be displayed in the UI when in use.
o [4929] Removed 'Close' right-click menu options from all menus.
o [4957] The plug-in system now supports processing of MultiPOP and DomainPOP
collected mail. See plugins.txt for more information.
o [4591] The full name field is now populated for contacts that MDaemon adds
to the default address book when an account sends mail.
o [5039] Reworked the gateways UI to use more consistent terminology and to
get rid of some of the unneeded text cluttering it up.
o [5040] It is no longer required to first remove a queue from the queue
editor when disabling a gateway's auto-spool option.
o [5018] Removed option to "bounce" spam message from the spam filter UI.
If there is a need to bounce a known spam it can still be done by setting
the following manually in CFilter.ini:
[SpamFilter]
BounceSpam=Yes (default no)
Setting this switch will cause MDaemon to ignore the other spam disposition
options (delete, spam trap, and flag)
o [5034] Added option to import original message text into body of MDaemon
generated DSN messages. The option is disabled by default because this
makes the DSN messages twice as big. To enable, edit the following in
MDaemon.ini:
[Special]
ImportMessageIntoDSN=Yes (default No)
o [5057] Added "Message Size" test to user-defined IMAP filter rules. This
works with the new "is greater than" and "is less than" tests which were
also added. It also works with "is equal" and "is not equal" tests.
o [5021] Bayesian learning will no longer take place when using external spam
daemons (there's no point really). Also Bayesian learning process was some-
times logging failures needlessly (for example, when learning was disabled).
o [5022] Added option to Misc Options|Misc to enable/disable the counting of
groupware (non-mail) folders when using disk/file quotas. Also, renamed
"Use Strict Quotas" to "Include all inbox sub-folders in quota calculation"
which is a little more descriptive.
o [5054] The retry queue is now employed for all delivery options. The Setup
Delivery UI was greatly changed due to this. So, whether you are delivering
directly, sending all mail to another server, or sending problem mail to an-
other server, the retry queue should be involved.
o [5027] Added option to Retry UI to move undeliverable DSN messages into the
bad message folder. This applies only to DSN's that MDaemon has generated.
o [5042] Police up references to "MDaemon AntiVirus" in MDaemon.exe. Those
references should be changed to "SecurityPlus" if MDAV version >= 3.00.
o [5049] Added session window right-click menu option: "Add to IP Screen"
which adds the IP address of the selected session entries to the "All IPs"
section of IP Screen.
o [4986] When using Active Directory monitoring and specifying an "alias"
value for accounts in ActiveDS.dat MDaemon will append '@<domain>' to the
expanded value but only if the value doesn't already have a '@' char in it.
For example, Alias=%givenName%_%sn% (the default) wouldn't normally yield a
'@' character whereas Alias=%mail% probably would. In the first case,
'@<domain>' will be appended. In the second, it won't.
o [4622] Added paging support to WorldClient's task view. This should improve
the rendering speed for larger task lists.
o [4971] Added percentage calculations to all relevant sub-nodes on Stats tab.
o [5241] SyncML: Tasks now support a date range filter. For example
Tasks?/dr(-7, 7) will only synchronize tasks without a due date or
where the due date is up to seven days in the past or future.
o [5247] Added composite log switch for logging plugin activity
o Returned default spam/ham Bayesian required samples to 200 each.
o [3847] MDStats displays the MDAV and OC registration keys
o [2887] MDStats supports message sizes larger than 2 GB
o [4779] MDStats supports directory sizes large than 2 GB
o [4879] MDStats displays message & directory sizes with thousands separators
FIXES
o fix to Firefox requiring the entire page to reload when an AJAX request was
being made in some instances
o fix to cfengine waiting too long to process a message once mdspamd.exe is
restarted
o [4755] fix to Japanese MDaemon signature possibly corrupting message text
o [4771] fix to options in CFilterGUI not grayed when scanner disabled
o [2371] fix the list boxes on the public folder screen of cfilter to scroll
if public folder names were long.
o [4793] fix to PTR "domain not found" closing connection errantly
o [4804] fix to mdspamd looking for site config paths
o [4802] fix to mdspamd to not create the spamd-XXXX-init folders needlessly
o [4816] fix to SyncML is unable to synchronize tasks with SonyEricsson z520
o [4821] fix to temp queues cleared on startup (functionality deprecated)
o [4834] fix to ghost unable to create SEM files to signal MDaemon for things
o [4835] fix to CFEngine/MDSpamD process shutting down when Ghost starts up
o [4797] fix to not marked as spam when score exactly equals threshold
o [4847] fix to LogonToNetwork being called and user impersonating taking
place even when not running as a service
o [4854] fix to LogonUser() called once/thread rather than once/process
o [4856] fix to "Could not start process X as user Y on domain Z" errors (fix
needs confirmation).
o [4857] fix to archival and public folder copies of system generated mail
going through content filter when not configured to do so
o [4863] fix to crash/corruption when Network Resource Access UI saves data
o [2236] fix to log files not rotating due to ghost session connected
o [4867] fix to errant handling of certain catalog requests
o [4868] fix to service restarting as an application and not a service
o [4882] fix to wrong CopyFile function getting called at times
o [4502] fix to the day view not scrolling to the first event or the work day
when an all day event exists
o [4925] fix to % calculations being wrong in the GUI
o [4941] fix to MDSpamD being restarted needlessly by the UI
o [4932] fix to filelist-xx.dat file referencing deprecated killfile.sup
o [4938] fix to MDLaunch not stopping/starting MDaemon server/app correctly.
MDLaunch will now always start MDaemon as a service if the service exists.
o [4897] fix to SyncML: Marking task complete does not set date completed
o [4900] fix to SyncML: When synchronizing calendar events, changing the date
range does add or delete events from the client
o [4902] fix to SyncML: Date range based on current time rather than midnight
o [4908] fix to SyncML: When sent to the client, the start date for recurring
events is set to the first occurrence within the date filter
o [4910] fix to SyncML: Recurring events ending on the last day of the date
filter will not be sent to the client
o [4911] fix to SyncML: Monthly recurring events sent to the client may occur
on the wrong day
o [4912] fix to SyncML: Monthly by day recurrence sends weekday information
o [4913] fix to SyncML: RRULE sent for "last week of month" contains "1-+"
o [4914] fix to SyncML: An event from the client with monthly by position
recurrence for multiple weekdays will not be added to the server
o [4915] fix to SyncML: Only the first line of a street address is sent
o [4916] fix to SyncML: Commas in contact categories converted to semicolons
o [4917] fix to SyncML: When only one of a contact's email addresses or
websites is specified, it may appear in the wrong field on the client
o [4949] fix to Spam Filter UI restarting MDSpamD even when clicking Cancel
o [4945] fix to bad Content-Type header generated from RAW messages having
attachments to multiple recipients
o [4955] fix to plug-in SMTPMessageFunc calls not working for MDAV trial keys
o [4967] fix to UI unable to open OC release notes
o [4968] fix to purchase/upgrade option not always redirecting to correct site
o [4970] fix to AUTH not working when smart host enclosed in brackets
o [4948] fix to delivery not moving to next MX when A record lookup times out
o [4947] fix to SyncML logs are not overwritten
o [4898] fix to SyncML not supporting task states "In Progress" and "Deferred"
o [4972] fix to Stats tab counts not initialized properly on startup
o [4973] added msg/per hour stats to UI and statistics report
o [4742] fix to configuration session whitelist changes not being honored
without restarting MDaemon
o [4740] fix to some .cf files getting blanked out when using foreign MDSpamD
o [4688] fix to Empty Trash not working in .XHTML theme
o [4714] fix to long names wrapping onto two or more lines in the LookOut
Contacts view
o [4989] fix to DomainKeys verification of Gmail messages fails
o [2329] fix to session transcript not included in DSN at times
o [4866] fix to smart host not used on 4xx errors at start of mail session
o [5008] fix to some plug-in functions working when they shouldn't
o [5009] fix to About page showing AV trial days left twice
o [5046] fix to "MAIL FROM" sometimes yields unexpected results bug
o [5020] fix to contact records overwritten with each use of list editor
o [5013] fix to SyncML VCARD parser may not read the type of an address of
phone number
o [5029] added support for PLAIN authentication mechanism to IMAP server
o [5033] fix to truncated welcome message subject in Russian version
o [5045] fix to Bayesian learn button disabled in ghost/configuration sessions
o [5047] fix to IPScreenEditor::Add allows banning of local and trusted IPs
o [5050] fix to session window right-click "Print/Copy" doesn't work right
o [4987] fix to greylist whitelist and advanced edit dialogs disabled
improperly
o [4984] fix to hard-coded "Select Directory" string in UI
o [4425] fix to public folder ACL's not updated when user deleted
o [4556] fix to 530 SMTP error code not generating DSN immediately
o [5072] fix to .ctl files not removed when .msg deleted using UI
o [5074] fix to "Create missing reply-to header" option using envelope value
rather than FROM header value. This broke BATV and VERP systems.
o [4177] fix to spam filter exclude list not working both ways with aliases
o [5095] fix to remote queue timing out delivery attempts when certain SMTP
errors occur
o [4029] fix to authenticated sessions allowed to send to unknown local users
o [5097] fix to WC not updating filters to subfolders of a renamed folder
o [5126] fix to plugin manager object not optimally initializing itself
o [3250] fix to Comagent may crash if an HTTP connection error occurs
o [5124] fix to MD3Conv errantly displaying an upgrade dialog
o [5127] fix to 127.0.0.1 being allowed as valid A record result by resolver
o [5130] fix to configuration sessions killing CFEngine when they shut down
o [4617] fix to read receipt generated by WC trashing international characters
o [5154] fix to gateways with wild-carded domain names not working correctly
o [5144] fix to trusted IP/domains made via ghost not replicated to main MD
o [5131] fix to many bugs in MDaemon's shutdown sequence
o [5158] fix to possible CFEngine.exe lockup when trying to create temp and
work directories
o [5182] fix to USER_IN_BLACKLIST_TO score being overwritten in local.cf
o [5047] fix to IP screen UI allowing banning of local and trusted IPs
o [5202] fix to possible cfengine.exe queue lockup
o [5208] fix to weekly recurring event added by SyncML does not appear
in Outlook (Outlook Connector)
o fix to some memory leaks in MDaemon and WorldClient
o [5145] fix to IMAP filter rules showing groupware folders
o [4806] fix to free/busy data is not available for attendees added from the
contact picker
o [4691] fix to invalid calendar XML may cause the Outlook Connector to crash
o [5172] fix to WC compose caching deleted CC field
o fix to memory leaks in DomainKeys signing and verification
o [5219] fix to JavaScript error in WorldClient category picker applet
o [5226] fix to potential JavaScript exploit in WorldClient
o [5237] fix to SyncML: Marking a task as "not completed" on the client does
not update the server
o [5238] fix to SyncML: Calendar events with a new line in the comments
field will cause SyncBerry to fail
o [5243] fix to SyncML: Email addresses are not updated when a contact is
edited on the device
o [5244] fix to SyncML: A contact with only a company name will appear as
"none" or "unnamed" in the contact list on the device
o (beta only) fix to SyncML: Phone numbers are not updated when a contact
is edited on the device
o [5242] fix to changing spam threshold rendering auto-learning ineffective
o [5245] Composite log settings are now in the Logging Options rather than
the Misc Options GUI.
o [5246] fix to composite log logging unknown types by default
o [5249] fix to GUI allowing empty IMAP delimiter character
o [5210] fix to meeting attendees may not be saved
o [5211] fix to cannot delete all meeting attendees
o [5216] fix to EXITNOW.SEM causing thread dead-lock and app not exiting
o [5217] fix to beta and trial end-of-life causing thread dead-lock and app
not exiting
o [5218] fix to activation period expiration causing thread dead-lock and
app not exiting
o [5203] fix to mail directory possibly ending with ".\" or containing ".\"
o [5225] fix to UI allowing MDSpamD connections/thread > 200
o [5197] fix to right justified "one per line" toolbars when using taskbar
