AutoRun Pro Enterprise
Ага, 7-ка уже есть. Жаль, лекарства к ней нет А 6.0.1.50 уже в сети не видно
AutoRun Pro Enterprise v7.0.0.60
прога+кейген (пар.:_http://netz.ru ) 7.37 MB
AutoRun Pro Enterprise v7.0.3.63
прога+кейген (пар.:_http://netz.ru ) 7.32 MB
AutoRun Pro Enterprise v8.0.0.71 7641KB
Features
• Display of every registered document (e.g.: TXT, DOC, HTML) via automatic start of the corresponding application.
• Print of every registered document (e.g.: TXT, DOC, HTML) via automatic start of the corresponding application.
• Start any program.
• Start the default browser with document URL.
• Send email.
• Integrated Web browser and internal commands.
• Integrated sound player.
• Integrated AVI video player.
• Integrated RTF (Rich Text) viewer.
• Integrated Media Player.
• Slide Show images (Photo album), more than 100 styles.
• Background color, Gradient color and Transparent Form.
• Background sound.
• Splash screen, splash screen sound.
• Full screen background and logo image.
• License agreement. You can display a license agreement before any files are launched. The user is required to accept the license in order to continue. If the user does not accept the license, then the AutoRun exits.
• Security. You can protect your CD from being started by unlicensed users by requiring users to submit a User Name and Password or an Authentication Code.
• Exit Form. Show information or confirm exit before program exits
• Unlimited Sub Pages.
• Page FadeIn, FadeOut.
• Page Shadow.
• Images include bitmap, icon, JPEG, EMF, WMF, GIF (Static or Animated), PNG images.
• Page template.
• Object template.
• CD Icon and Page icon can be displayed in the title bar.
• Test without burning CD.
• Burn project to CD-R/CD-RW directly with built-in CD Burner.
• Create a single executable file.
• Publish project to new folder.
• Create ISO CD-ROM image file.
• Install Software - You may want to install a default viewer for the files if the user does not have one on his computer. For example, if you are launching a PDF file, you may want to include Adobe Acrobat Reader software on your CD and install it if the user does not already have it installed. You can define one or more files to be installed.
• Create tabbed notebook style application for autorun CDs. It is very easy.
• Create drop down menu bar for pages like most standard windows to make your page more professional.
• CD expire date, Specifies an expiration date for the CDs.
• Customized hint let users use customized tool tip window instead of the original system tool tip window.
• Object group operation.
• Set object(s) Enable or Disable, Show or Hide Object(s).
• Action Group (Click Action or Start Action) for more than one action on user click or start a page.
• Check style for Button, ImageButton, Image and SimpleText Objects (Mouse down state indicate the object is selected).
• No programming knowledge required.
• No registry entry necessary.
• Runs from CD-ROM without installation.
• No runtime module required.
Как увидеть ссылки? | How to see hidden links? Как увидеть ссылки? | How to see hidden links? Как увидеть ссылки? | How to see hidden links?
AutoRun Pro Enterprise v.8.0.0.71 - KeyGen/Crack:
_http://www.badongo.com/file/732233
AutoRun Pro Enterprise v.8.0.0.71:
_http://www.longtion.com/autorunenterprise/ARPESetup80.exe
Русик к AutoRun Pro Enterprise v8.0.0.70, а также к предыдущим версиям
можно найти тут: _http://www.msilab.ru/show.php?rus=553
О Faq
А есть какой-нибудь FAQ по энтой проге, а то я никак не могу найти, где у нее и как прописать чтоб она начинала демонстрацию фильма.
Хотел сделать авторан для дисков с фильмами - открыть папку для просмотра файлов - работает; выход - работает; а чтоб начинала воспроизводить фильм в дефолтном плеере - не могу заставить.
Посоветуйте,fплиз. Как увидеть ссылки? | How to see hidden links?
igrok54
Если дефолтный плеер понимает консольные команды, то запуск фильма можно прописать что-нибудь вроде <player.exe film.avi> . Если дефолтный пдеер player.exe понимает такую комбинацию как команду воспроизвести нужный фильм film.avi то все в порядке.
Продолжить обсуждение этого вопроса следует вразделе программы, например в теме:
Или создать тему по обсуждению настроек данной программы.
В разделе варез только о варезе!
Longtion AutoRun Pro Enterprise v.10.0.0.105 ; 7,43MB (комплект, Incl. KeyGen-tsz):
_http://www.mytempdir.com/944073
Пароль на архив / Rar password: dv-netz.ru
Как увидеть ссылки? | How to see hidden links? для Longtion AutoRun Pro Enterprise v.8.0.0.71
"Свою" версию русифицирует процентов на 80, 10-ку русифицирует с ошибками. Однако ни визуальньно, ни функционально на первый взгляд эти версии не отличаются, так что сторонникам локализованных версий программ рекомендую пользоваться 8-й (ссылка в "шапке" - живая).
Реакции: Msha
