L
LARRI
подкажите в чем может быть проблема скачал BSplayer1.32.820 поссылке от 02.08.05 ,не могу извлечь из RAR , установить напрямую тоже не получается,перепробовал кажется все варианты.HELP PLEASE!!!
• reorganized rendering modes
• added basic support for VMR7
• better support for locked files (files that are still downloading)
• player will now stay in desktop mode after movie is finished
• in frame step mode aspect ratio won't change anymore
• external subtitles will now work when embedded are present
• player will now come to foreground when new movie is started
• fixed CDDB problem
• fixed crash when close or minimize button was clicked
• fixed bug with subtitles in TMPlayer format, last line was not displayed
• fixed problems with some VobSub subtitles
• ar command line option was broken, fixed
• some bugs with .bsi files fixed
• more compatible with Haali splitter
• audio input for TV tuner is now properly remembered (Pro only)
• some other bug fixes
h**p://lajbaorg.temp.powweb.com/pliki/bsplayer139.829.[amnezja.org].exevideo window border is now 'normal' again
some fixes for WMV files encoded with screen encoder
some other small bug fixes
kostos сказал(а):Galed
В комплекте BSplayer Pro version 1.38.828 и серийный номер.
