Component Pro Ultimate Studio Suite 2020.Q1 v7.2.234
The cracked version of Ultimate Studio for .NET includes all the powerful Ultimate Components (Mail, SFTP, SFTP Server, FTP, ZIP, SAML, Netkit, Encryptor, Excel, Word, PDF, PDF Viewer, BounceInspector, and TemplateEngine) for .NET Framework, Mono, Xamarin Android, Xamarin iOS, Mac, UWP, Portable Class Library and Silverlight.
FTP Component
Ultimate FTP is a 100%-managed .NET class library that adds powerful and comprehensive File Transfer capabilities to your .NET applications.
SFTP Component
Allows you to easily and efficiently develop a broad spectrum of SSH secure file transfer applications in C#, VB.NET and ASP.NET.
SFTP Server
Create your own SFTP & SCP server to provide secure remote file system access over an SSH channel using the SFTP protocol with a few lines of code.
PDF Component
A high-performance and reliable PDF library which lets you add PDF functionality to your .NET and Silverlight applications easily with a few lines of code.
PDF Viewer Control
A control that adds PDF document visualization to your .NET WinForms applications.
Word Component
A high-performance and reliable Word library which lets you add Word functionality to your .NET and Silverlight applications easily with a few lines of code.
Excel Component
A high-performance and reliable Excel library which lets you add Excel functionality to your .NET applications easily with a few lines of code. Ultimate Excel is now available for .NET and Silverlight.
Zip Component
A high-performance and reliable Zip library which lets you add zip/unzip functionality to your .NET applications with a few lines of code.
Saml Component
An OASIS SAML v1.x and v2.0 specifications compliant .NET toolkit which offers an elegant and easy way to add support for SSO SAML 1.x and 2.0 to your ASP.NET applications.
Mail Component
The Ultimate Mail Component offers a comprehensive interface for sending, receiving e-mail messages from a server and managing your mailbox remotely.
Terminal Component
Easily add SSH and Telnet connectivity to your .NET applications. In addition, it also adds exclusive SSH Terminal Emulation Control to your WinForms App.
Mail Merge
Ultimate Mail Merge, a part of the Mail Expert package, helps you send personalized e-mail messages utilizing the power of .NET Framework.
Bounce Inspector
A high-performance Bounce Inspector that enables your .NET applications to easily inspect and categorize bounced email messages with a few lines of code.
Email Validator
A 100%-managed .NET class library that adds powerful and comprehensive e-mail address validation to your .NET applications without sending e-mails to recipients.
Template Engine
Easily generate formatted text output from source template, input variables, and .NET classes with few lines of code.
Encryptor
Intuitive encryption API. Supports encryption and decryption of files and streams; XTS-AES, AES, 3DES and Twofish in CBC mode, password-based protection and PBKDF2 key derivation.
DNS Component
A powerful .NET library that lets you query DNS servers for resource record types defined by RFC-1034 and RFC-1035.
TraceRoute Component
Comphrehensive interface for sending Echo messages (Ping) and performing Internet Route Tracing to determine network delays and topology.
WhoIs Component
Performing domain registration lookups easily with a few lines of code.
IPLookup Component
Easily find from which countries your visitors are coming from.
Time Component
Getting exact time from and keeping all the computers running your application synchronized with public time servers over the Internet.
Proxy Component
Fully supports HTTP CONNECT, SOCKS4, SOCKS4A, and SOCKS5 proxy servers. By simply setting a few properties, you are able to get connect through the desired proxy server
SFTP Component
SFTP Server
PDF Component
PDF Viewer Control
Word Component
Excel Component
Zip Component
Saml Component
Mail Component
Terminal Component
Mail Merge
Bounce Inspector
Email Validator
Template Engine
Encryptor
DNS Component
WhoIs Component
IPLookup Component
Time Component
Proxy Component
Hidden content. You need to Как увидеть ссылки? | How to see hidden links? or Как увидеть ссылки? | How to see hidden links?.
