1
147
streamdown, держи _ftp://203.153.34.138/CORELDRAW[/url] - 11
http://rapidshare.com/files/35777638/CDGSX3_v13.0.0.739.part01.rar
http://rapidshare.com/files/35785099/CDGSX3_v13.0.0.739.part02.rar
http://rapidshare.com/files/35787359/CDGSX3_v13.0.0.739.part03.rar
http://rapidshare.com/files/35789554/CDGSX3_v13.0.0.739.part04.rar
http://rapidshare.com/files/35791871/CDGSX3_v13.0.0.739.part05.rar
http://rapidshare.com/files/35796630/CDGSX3_v13.0.0.739.part06.rar
http://rapidshare.com/files/35798987/CDGSX3_v13.0.0.739.part07.rar
http://rapidshare.com/files/35801488/CDGSX3_v13.0.0.739.part08.rar
http://rapidshare.com/files/35803212/CDGSX3_v13.0.0.739.part09.rar
слушай, у меня оттуда ДЛЛ-ки да и кабы не качает...мож есть где одним куском?streamdown, держи _ftp://203.153.34.138/CORELDRAW[/url] - 11
Ребята я из Болгарии и не говорю русского язика очень хорошо и поетому я написал инструкция на Английскому язийку.
Попрошу кому то перенаписать етатя инструкция на русскому язийку.
Perfect Install:
1. After Downloading the Corel Draw X3 Pack (incl. SP1 and SP2) please disconnect from Internet (the best way is to plug off the cable from your LAN card)
2. Please use one of the following KeyGens (RESPECT: SSG and ECHOS), please be advice that COPY/PASTE is NOT working (the solution for quick entering of the serial is to COPY [from keygen] PASTE [into the field] DELETE the last symbol and write it back via keyboard. DO NOT CLOSE THE KEYGEN!!!!!
3. Install the product and DO NOT CONNECT THE INTERNET!!! DO NOT CLOSE THE KEYGEN!!!!!
4. When the installation is finished and you try to start the product for first time you will choose an option Aready purchased, please be advice that the Corel Programmers are forgot to insert into their product the option of PASTE HANDLER, so for this reason you need to input the serial number manuallyDO NOT CLOSE THE KEYGEN!!!!!
5. Use the option to activate the product via PHONE and from the generated Installation ID copy it without the middle dashes and put it to the KeyGen and GENERATE the Activation Code. DO NOT CLOSE THE KEYGEN!!!!!
6. Insert the generated code manually in the needed field (do you remember that COPY/PASTE is NOT working?)
7. Now the product is ACTIVATED, but is WITHOUT SP1 or SP2
8. Install CGSX3SP1.msp - Service Pack 1
9. Install CGSX3SP2.msp - Service Pack 2 - PLEASE READ CAREFFULY THE INSTRUCTIONS BELOW
10. Please put the option to find HIDDEN and SYSTEM files in windows, if you don't know how please look in GOOGLE
11. Search for file named: DR13.dta (look in: C:\Program Files\Corel\CorelDRAW Graphics Suite 13\Programs\ if you have an a standart installation ) and DELETE it (usually I RENAME it like: DR13.dta.BAK)
12. Please START again Corel Draw Graphic Suite X3 SP1 and in the selected field insert: DR13WTX-0000046-GDR (DO NOT CONNECT TO INTERNET)
13. Start again the installation of: CGSX3SP2.msp - Service Pack 2 (DO NOT CONNECT TO INTERNET)
14. When the installation is finished please CONNECT to INTERNET (so put your LAN cable back into the LAN card)
15. Voila and Happy Using of Corel Draw X3 SP2
by ERROR_404
А может у тебя уже стоит версия с SP1?В чем может быть дело?
