Corel DRAW (все версии)
CorelDRAW_Graphics_Suite_X4_v14.0_MULTiLANGUAGE-CYGiSO (DVD)
Language: English, French, German, Italian, Dutch, Spanish, Brazilian Portuguese
Content (clipart/photos/fonts/templates)
CorelDRAW Graphics Suite X4 delivers incredible value with all this additional content*:
• 10,000 high-quality clipart images, individually selected to meet the needs of design professionals and occasional users alike
• 1,000 high resolution, royalty-free photographs from iStockphoto®
• 1,000 OpenType fonts, including 75 Windows® Glyph List 4 (WGL4) and 10 single-line engraver fonts
• 80 professionally designed templates
Code:
Русскую версию можно скачать с официального сайта
_http://www.corel.com/akdlm/6763/downloads/trials/GraphicsSuiteX4/CorelDRAWGraphicsSuiteX4Installer_RU.exe (354,72 MB)
Кто знает где можно скачать Corel 11 версии желательно с русским языком?
Цитата:
Сообщение от djDan
Скачал, поставил - РАБОТАЕТ......
А как регистрация?
CorelDRAW Graphics Suite X4 v14.0 - Install Guide
-=-CorelDRAW Graphics Suite X4 v14.0 *MULTiLANGUAGE*-=-
ver. 14.0.0.567
by ERROR_404
!README CARREFULLY AND DON'T ASK LAME QUESTIONS!
===User Installation Guide===
1. DISCONNECT FROM INTERNET
2. Mount the *.ISO with Daemon-Tools
3. Start the setup program
4. Run the provided KeyGEN and generate key it will generate something like: DR14*****************************
5. Don't close the KeyGEN!!!
6. At installation choose "I have a serial number" and generate a key with the provided KeyGEN
7. At the setup click on "Options" and deselect "Product updates"
8. Start the program and if ask for serial please fill the serial from the provided KeyGEN choose "PHONE COREL" the application will generate Installation Code
IMPORTANT NOTE: When install is running, keep KeyGEN open and don't press generate a new serial, because the Installation Code depends on the Serial number and ID.
Copy the Installation Code without "-" to the KeyGEN.
For example, if your Installation Code is:
XXDW-IXV1-RN0I-3EUH-2U48 then copy
XXDWIXV1RN0I3EUH2U48
to the keygen and press Activation code
9. Paste the generated Activation code from the KeyGEN to the application screen and click "CONTINUE" and "FINISH"
10. START USING THE PROGRAM
VERY IMPORTANT NOTE:
To work property on CorelDRAW X4 you need to stop "Protexis" as a licensing service
(perhaps you forgot to uncheck the SETUP->OPTIONS->[uncheck "Product updates"])
To solve this problem you need to follow this steps
1. Right mouse click on My Computer->Manage->Services and Applications->Services->"Protexis Licensing V2"
DISABLED and STOP
2. Start search "Protexis" in windows registry
START->RUN->REGEDIT->[F3]->"Protexis"
DELETE ALL KEYS
3. Try run the program and if we start CorelDRAW Graphics Suite X4 and receive "Product installation unsuccessful, please reinstall" or "ERROR 38" this means that the "Protexis" service is not started and the application will exit. This is good.
4. We need to found c:\Documents and Settings\All Users\Application Data\Corel\CorelDRAW Graphics Suite X4\DR14.dta
and delete the DR14.dta
5. Next you need to mount again the *.ISO image via Daemon-Tools
6. REMOVE CorelDRAW Graphics Suite X4
7. On the main application screen choose again to install CorelDRAW Graphics Suite X4
8. Follow the steps above (User Installation Guide)
----------------README---------------
Now before connecting to INTERNET go to your Windows Firewall or another Firewall Program that you use and make sure that:
C:\Program Files\Common Files\Protexis\License Service\PsiService_2.exe
was added to be blocked, so in Windows Firewall:
Change Windows Firewall Settings->Exceptions->Add Program->[BROWSE TO THE PATH ABOVE]->Click on the "PsiService_2.exe"->EDIT->Change Scope->Custom List->127.0.0.1/255.255.255.255 (you need to add 127.0.0.1 or localhost)->OK->OK
IMPORTANT REGISTRY KEYS:
HKEY_LOCAL_MACHINE\SOFTWARE\Protexis
HKEY_USERS\.DEFAULT\Software\Protexis
HKEY_LOCAL_MACHINE\SOFTWARE\Corel\CorelDRAW\14.0
HKEY_LOCAL_MACHINE\SOFTWARE\Corel\Setup\CorelDRAW Graphics Suite 14
IMPORTANT SYSTEM PATHS
ERROR_404
741 Вот еще бы русский язычок к нему а то русификаторы SP1 u 2 не ставятся :(
STBiffen, недавно случайно грохнул у себя папку с "музейным" софтом :(, там всё это было
STBiffen
_http://rapidshare.com/files/119529667/inst11draw.part1.rar
_http://rapidshare.com/files/119532355/inst11draw.part2.rar
_http://rapidshare.com/files/119533612/inst11draw.part3.rar
mrr:
_http://depositfiles.com/files/5741399
_http://depositfiles.com/files/5741660
_http://depositfiles.com/files/5741805
• язык: eng/rus
• серийник в комплекте.
________
CorelDRAW Graphics Suite X4 SP1 Full/Upgrade (English, German, French, Italian, Dutch, Spanish, Brazilian Portuguese, Swedish, Finnish, Russian, Hungarian, Czech, Polish)
_http://www.corel.com/servlet/Satellite/us/en/Content/1157481830155?pid=1213733086367
CGSX4SP1.exe (42.0 MB)
CorelDraw Graphic Suite X4 14.0.0.653 SP1 (Русская версия)
ВНИМАНИЕ!
Те, у кого уже установлена программа CorelDraw Graphic Suite X4 14.0.0.567 - отключают интернет и обновляются SP1 до версии: 14.0.0.653
Проблем при обновлении не возникает.
Язык интерфейса: Русский
Размер SP1: 41,2 Mb
с Rapidshare.com:
http://rapidshare.com/files/135754096/x4_14.0.0.653_rus.part1.rar
http://rapidshare.com/files/135754311/x4_14.0.0.653_rus.part2.rar
http://rapidshare.com/files/135754521/x4_14.0.0.653_rus.part3.rar
http://rapidshare.com/files/135754802/x4_14.0.0.653_rus.part4.rar
http://rapidshare.com/files/135754815/x4_14.0.0.653_rus.part5.rar
с DepositFiles.com:
http://depositfiles.com/files/7079917
http://depositfiles.com/files/7079940
http://depositfiles.com/files/7079965
http://depositfiles.com/files/7079987
http://depositfiles.com/files/7079989
