Z
zhuk
InstallShield Products
InstallShield 10.5 SP1 Premier Edition
InstallShield 10.5 provides software publishers with the leading solution for authoring strong and reliable Windows Installer (MSI), InstallScript™, and cross-platform installations.
Top 9 Reasons to Use
1. The Complete Installation Solution
With support for every platform and operating system you target, InstallShield 10.5 gives you the power and flexibility to easily develop all Windows Installer (MSI), InstallScript™, cross-platform, and mobile device installations with just one tool.
2. Support for Microsoft's Recent MSI 3.0 Release
InstallShield 10.5 supports all projects built with the new Microsoft Windows Installer (MSI) 3.0 to simplify your patch development.
3. Configure Products to Run as Trialware Easily With No Changes to Your Code
With new Trialware functionality, you can quickly get evaluations of your product into the marketplace to let customers and prospects try before they buy, by setting it to run for a specific number of days before expiring.
4. Keep Users on the Most Current Version of Your Software
Communicate directly with end users after they have installed your application. Easily deliver updates, patches, and marketing messages using the Update Service Starter Edition with no change to your code at no additional cost.
5. Share Project Assemblies Across Different Products
InstallShield 10.5 allows developers to divide large projects into smaller pieces. These pieces, known as "Assemblies," are reusable modular components that can be incorporated into multiple installations simply by plugging them in, improving the way applications are built, deployed, and maintained.
6. Reduce Development Time and Support Costs
Building one installer to deploy your products onto multiple platforms saves significant time and development effort. Simplify product documentation and testing requirements, cut down development time, and reduce support calls.
7. Unlimited Strength and Reliability
InstallShield 10.5 takes installation power and flexibility to a new level. Precisely configure your installers quickly and easily with our unmatched selection of automated tools and intuitive wizards.
8. Create Higher-Quality Installations in Less Time
Automated tools and wizards make even your most advanced installation requirements a snap to configure. Conflict elimination features ensure bulletproof installations for a seamless end-user experience.
9. Easily Expand Installations to Servers
Powerful features simplify and accelerate your MySQL, SQL Server, IIS Web Services, and Ant installation projects. Not having to write custom script saves your developers production time, and ensures accurate and reliable installs.
InstallShield 10.5 has built-in support for the following:
Operating systems and platforms
WINDOWS (win XP, 2000, 2003, 9x) x86 and Itanium (where applicable)
AIX (v5.1 and greater) 32 and 64 bit
HP UX (v 10.x and greater) - Itanium and PARISC
LINUX (wide range of Linux OS's including Red Hat, Suse, Mandrake, Caldera, and others) x86, Itanium, AMD64
MAC (v10.0 and greater)
OS/400 (v5R1 and greater)
SOLARIS (v8 and greater) - SPARC, x86
Several other UNIX Platforms through our Generic UNIX PPK modules
JVMs Supported:
Sun 1.2.2, 1.3.x, 1.4.x, 1.5.x
IBM 1.3.x, 1.4.x
HP 1.2.2, 1.3.x, 1.4.x
Apple 1.2.2, 1.3.x, 1.4.x
_________________
Site: http://www.installshield.com/products/installshield/
All Features:
http://www.installshield.com/products/installshield/premier/features.asp?source=pre&fv=2#topinstallationdevelopers
InstallShield 10.5 Datasheet (512KB PDF):
http://www.installshield.com/downloads/installshield/aag.pdf
InstallShield v10.5 Premier SP1 for Windows (492.4 MB):
http://saturn.installshield.com/is/10.5sp1/premier/full/package/installshield1050sp1premier.exe
InstallShield v10.5 SP1 (Update Only) (7.3 MB):
http://saturn.installshield.com/is/10.5sp1/patch/installshield1050sp1.exe
InstallShield v10.5 Premier SP1 for other platforms:
http://saturn.installshield.com/is/10.5sp1/universal/premier/full/installshielduniversal_genericunix.sh (56.0 MB)
http://saturn.installshield.com/is/10.5sp1/universal/premier/full/installshielduniversal_linux.sh (81.0 MB)
http://saturn.installshield.com/is/10.5sp1/universal/premier/full/installshielduniversal_hpux.sh (119.6 MB)
http://saturn.installshield.com/is/10.5sp1/universal/premier/full/installshielduniversal_mac.zip (56.0 MB)
http://saturn.installshield.com/is/10.5sp1/universal/premier/full/installshielduniversal_solarissparc.sh (83.2 MB)
Hidden content. You need to Как увидеть ссылки? | How to see hidden links? or Как увидеть ссылки? | How to see hidden links?.
_________________
InstallShield X SP2 Express Edition
For quick and easy installations, the InstallShield X Express Edition is the industry standard. Reliable setups can be built in record time without any training, allowing setup authors to target Windows, Linux, and mobile devices with ease.
Remarkably Quick and Easy to Use
The Express Edition is easy to use, shielding you from installation complexities of building a setup. You can rapidly build, test, and implement installations without any training. The Project Assistant helps you jump start a project with a point-and-click interface. The Live Redistributable Gallery enables popular technologies to be added to your applications using check boxes. A dedicated view written entirely in Java makes creating Linux installations fast and efficient. For internet setups, the Compact Installer quickly deploys an installation with the smallest overhead (less than 100k) of any installation engine. Notifying users of new updates after installation requires just a few clicks.
Setting the Standard for Reliable Installations
The product of more than twelve years of experience, the InstallShield X Express Edition has been consistently recognized as the industry’s premier rapid installation-authoring solution. Microsoft® and Borland® rely heavily on InstallShield X Express Limited Editions, shipping them with selected versions of their development tools.
Affordable Solution
The InstallShield X Express Edition is an extremely cost–effective solution that will fit into any budget. Now it’s possible for everyone to create professional–looking, industry standard installations.
_________________
Site: http://www.installshield.com/products/installshield/express/
Everything you need to know about the Express Edition in one simple document (984 KB PDF):
http://www.installshield.com/downloads/x/express/fact_exp.pdf
Download (127.4 Mb): http://saturn.installshield.com/express/x/domestic/full/setup.exe
_________________
DemoShield 8
DemoShield provides all the creativity without the complexity for building persuasive sales and product demonstrations, effective e-learning courses, compelling CD browsers and anything else you can imagine.
DemoShield is a quick and remarkably easy-to-use tool for creating interactive sales and product demonstrations, e-learning courses, CD browsers, and anything else that you can imagine right out of the box. Plus, DemoShield allows you to deploy your content over the web, on a CD-ROM, or as a standalone executable.
Fast Creation Time
Now anyone, regardless of creative ability, can blend audio, graphics, text, and video into engaging and entertaining demos in just a few clicks. Add buttons, pop-up menus, hyperlinks, and other interactive objects to your demos with a few clicks of your mouse.
Point-and-Click Simplicity
With wizards, templates, style libraries, and "How Do I" visual tutorials, you can jumpstart your project in a few simple steps.
Getting started is easy:
1. Jumpstart your project with the Demo Wizard where you can choose your project type, screen size, design theme, and scene layouts from hundreds of pre-built templates.
2. Import additional rich media images or videos, or capture screenshots from within DemoShield with the powerful Capture Images and Automation Wizards.
3. Make further annotations to each scene by adding text, shapes, graphics and sound.
4. Add objects like buttons, hyperlinks, edit fields and menus, then associate actions with each so your audience can interact with and navigate through your content.
5. Set transitions, effects and their timing individually for each scene and object.
6. As you get more comfortable you can add more advanced functionality like databases, events and variables to provide dynamic content, quizzes, feedback and localized language support.
7. And finally, package your project for deployment in seconds through the Distribution Wizard.
_________________
Site: http://www.installshield.com/products/demoshield/
Download (124.8 MB): http://saturn.installshield.com/demoshield/80/package/demoshield8esd.exe
_________________
Keygens in attach.
USEFUL APP: InstallShieldSkinCustomize
(1.8 Mb - http://rapidshare.de/files/766025/InstallShieldSkinCustomize.exe.html)
- create your own skins fof InstallShield products.
! THANKS VitaliM FOR INFO !
