QuickReport v5.05 for XE5 x32x64
QuickReport is a banded report generator written in 100% Delphi code that integrates very closely with Delphi and C++Builder. Design reports within the Delphi/C++Builder IDE using the form designer as a report designer.
Basic Features
Report Designing - QuickReport is a banded report generator written in Delphi. Integrated very closely with Delphi and C++Builder, reports are designed in the Delphi IDE, using the IDE form designer as a report designer.
Data connectivity - Quickreport can use any data component descended from the VCL TDataset class. The abstract table component provides a means to access any data that can be seen by Delphi or C++Builder while retaining all report features.
Output modes - reports may be sent directly to a printer, saved in document format for later viewing, or saved as HTML, PDF, XML, CSV, XL, WMF or ASCII format. HTML and PDF may be streamed for fileless output.
Features in detail
Standard preview Thumbnails and text search ...
Добавлено через 1 минуту
nrComm Lib Pro v9.27 for XE5 Full Source
The nrComm Lib is set of Delphi VCL components, classes and routines for serial communication tasks. Library helps to get access to various devices: serial port, data and voice modems, barcode scanners, Human Interface Devices (HID), Bluetooth, USB, LPT, GSM, GPS and others. It provides solution for quick implementation almost any packet data protocol. It can work with sound and speech. Library allows send SMS messages over connected mobile phone (GSM terminal) and much more.
nrComm Lib evolving since 1999 and lives over 12 years. Latest release supports most oldest and newest Delphi/CBuilder versions. Our project is always in progress and our team will include into product new features for support modern device interfaces and system API.
Добавлено через 2 минуты
ImageEn v4.1.4 for XE5 Full Source
ImageEn is an extensive component suite for image editing, display and analysis written in pure VCL code for Delphi and C++ Builder, and is also available for .NET. Thousands of software developers use ImageEn to add powerful multimedia functionality to their applications.
