TVideoGrabber Video SDK For Delphi, C++Builder, .Net & ActiveX v8.6 build 8.6.1.6 cracked
TVideoGrabber Video SDK for All versions cracked
Main thanks goes to DR for his excellent patch and JD for his easy url parser.
TVideoGrabber is a video capture / media player component for developers working with C#, VB, C++, Delphi, C++Builder, and ActiveX-compatible development tools. Powerful and simple to use, TVideoGrabber will help you to save time, money and effort to include video and/or audio capabilities in your project.
TVideoGrabber captures and records video and audio streams from HD USB webcams, HD cameras, DV cameras, IP cameras, screen, as well as from pictures used as video source.
It support popular software encoders like XVid, DivX,... as well as hardware encoders like Hauppauge PVR, Dazzle, Sensoray 2250S...
hbTapi v2.3 For Delphi & C++Builder All Versions (x32) cracked
The Telephony API (TAPI) is one of the most complex APIs of Microsoft Windows. hbTapi Components abstracts the API to some Delphi components which can be easily controlled by your application. hbTapi Components works through Microsoft's Telephony API to provide hardware-independence, this makes it easy to work with telephony devices from many manufacturers. It can be used with any TAPI compliant telephony hardware: low cost modems, ISDN adapters, professional telephony cards and switches etc.
