Ни укого не завалялась версия компонента VisioForge Media Player SDK 6 for Delphi 6-XE
очень нужно или подскажите где я могу его найти весь форум обыскал.
Neither ukogo not lying around version of the component VisioForge Media Player SDK for Delphi 6 6-XE
really need, or tell me where I can find it searched the whole forum.
DynamicSkinForm VCL v12.62 Full Source
DynamicSkinForm VCL - библиотека для поддержки скинов в приложении. Скины работают для форм, меню, хинтов, много стандартных и DB элементов управления. Библиотека также включает скины из Office2010, Ribbon UI контролы и Ribbon UI меню. Вы можете сами создавать скины в специальном редакторе.
DynamicSkinForm VCL library help you to create applications with skins. Skins support forms, menus, hints, many standard and non-standard original controls. Skins with many objects, effects help you to create standard and non-standard cool applications (like WinAmp, iTunes) Also you can create your skins with special editor.
DevArt dbExpress driver for InterBase, Windows v3.1.3
DevArt dbExpress driver for MySQL, Windows v5.1.3
DevArt dbExpress driver for Oracle, Windows v5.1.3
DevArt dbExpress driver for SQLite, Windows v2.1.3
DevArt dbExpress driver for SQL Server, Compiled v5.0.3
DevArt dbExpress driver for PostgreSQL v2.1.3
а одним архивом - жаба душит?
TMS IntraWeb Security System v1.0
The TMS Security System facilitates the definition of user rights on a menu or form level. In its user management features the TMS IntraWeb Security System relies on user/group profiles stored in a database.
The users can be grouped and can inherit rights in this way. Thereby you can integrate a highly sophisticated and close grained user management that closes all potential loopholes via shortcuts with minimal effort. Only if the user has been granted the specific right by the administrator he can see or use the specific function assigned by the administrator.
The administrator can configure the rights at run-time thereby preventing a restart of the program when changing assignments. For doing so he can use an easy to handle, intuitive GUI that enables the administrator to create new users or to group or delete them directly from the application.
