Fibplus 7.3 w/ source 2012 (no Internal version)
Dear friends,
Finally the FIbPlus 7.3 w/ source (no Internal version)
Please thanks rutracker.org member DimaGS5
FibPlus v7.3 FullSource :D
Version: 7.3
Year: 2012
Developer: Devrace
Platform: Borland Delphi 5-7, BDS 2005-2007 (Turbo Delphi / C + +), RAD Studio 2009, 2010, XE, XE2, C + + Builder 5-6, Kylix 3, gnat-3.15p, gnat2006 GPL, Borland InterBase 4. x-2007 and Firebird 1.x-2.x
Tablet: Not required - sources
Description
FIBPlus - is a powerful and yet simple and convenient component library for Delphi, C + + Builder, Kylix and Ada for direct access to InterBase and Firebird. We try to develop it in accordance with the wishes of our users, and each component, method and property are designed to address the challenges that each of you face every day.
Advantages of FIBPlus
Using FIBPlus in your applications, you get a number of important advantages, such as:
• Supports all versions of InterBase starting with 4.0 and Firebird 1.0 (including Embedded Firebird)
• Applications on FIBPlus do not require installation of additional software (drivers, BDE, ODBC, etc.) except the client software (gds32.dll, fbclient)
• Compatible with all standard and third-party db-visual components and report generators (TDBEdit, TDBGrid, TDBChart, ..., InfoPower, DevExpress, EhLib, IntraWeb, ASTA, FastReport, QuickReport, Report Builder, Context Database Designer, TMS Scripter Studio, TMSAdvDBGrid, DataAbstract, Fast Query Builder, Rave Report, Rubicon, Jazmine (JCW) ...)
• Improved performance in comparison with analogues. In particular, TpFIBDataSet works 30-40% faster than TIBDataSet IBX, uses 60-70% less memory and is 3-4 times faster with lookup-fields.
• Optimization of data exchange. FIBPlus has a number of tools to reduce network traffic, such as caching of metadata operations on entries in the local buffer without recourse to the server, packing of BLOB-fields with the help of the local BLOB-filters, re-use requests avtomodifikatsiya updating requests, etc.
• Unique features: repository configuration fields, queries, bug reports, centralized exception handling, support for Unicode, and much more.
Don't REPACK OR RE-UPLOAD
Please, I need your support, so, click in "THANKS"
Про эти фибы на дружественном форуме сказали, что редакторы не работают.
Dear friends,
Confirmed!
This versions is works as wished!
The main components (FIB) was compiled with sucess!
The Editors and Tools, in format BPL, is not for all version IDE OK = look the references (CB2011, XE2, etc...)
SO, you'll have that to compile!
Now this task, let each one of you! To be a programmer, you should not just break the head, but also learn to put the pieces lying on the ground
Just reminding everyone that Embarcadero has changed many concepts from their latest updates of the IDE, then many ways of encoding are not supported.
Thus, do not expect to be rosy from now on. Try to update and seek their own sources and means to circumvent the drawbacks of language.
Note 1: Take your mind, when we dont have one way, we must find another way! So... hands in work programming!
Note 2: Here, all compiled and working.... FIB + EDITORS + TOOLS -> IDE 2009, 2010, XE and XE2
Shell+ Components
Windows Shell Developer Tools
web site and examples : Как увидеть ссылки? | How to see hidden links?
Download :Как увидеть ссылки? | How to see hidden links?
Добавлено через 4 минуты
ZylGSM is a Delphi & C++Builder component that communicates with a GSM modem or phone with integrated modem (almost all new generation mobile phones).
Website : Как увидеть ссылки? | How to see hidden links?
Download : Как увидеть ссылки? | How to see hidden links?
Странно. У меня работают. Правда брал их дружественном форуме.
