Cindy v5.03 released!
Added TcyBook component:
328505
Also added TcyBook and TcyDebug demo.
TMS Component Pack 6.4.4.1 for Delphi & C++Builder 5-XE2 Full Source
Create modern-looking & feature-rich Windows applications faster with over 300 components in one money and time saving bundle.
TMS Component Pack for Delphi & C++Builder includes feature-packed grids, Office 2007 ribbon, Office 2003 style toolbar, planning/scheduling components, advanced edits, toolbars, internet auto application update, Office 2003/2007 style tabs, pager, panel, Outlook navigational controls and much much more...
Перезалейте пожалуйста, кто успел скачать)
EMS Advanced Data Export VCL 4.7.0.5 Full Source
EMS Advanced Data Import VCL 3.5.0.10 Full Source
great compenent. thank you
Добавлено через 7 минут
Еще есть маленький компонентик, но только для D7 и D2010. А может и к другим подойдет, я не знаю...
USB Component for Delphi7 and Delphi2010
can you share component support d2009 ?
Добавлено через 13 минут
It's work. thank you
Добавлено через 19 минут
EhLib Руководство разработчика
Содержание:
where is the component?
GMLib (Google Maps Library) Pre-Alpha Delphi 6 - XE2
Description
GMLib (Google Maps Library) are components that encapsulate the GoogleMaps API to administrate a map, markers, polygons, rectangles, polylines,.... All objects that you can put into a map. Actual components
- TGMMap: component to use the Google Maps map
- TGMMarker: component to show markers on Google Map map using the component TGMMap
- TGMInfoWindow: component to show a balloon with information
- TGMPolyline: component to show polylines
- TGMPolygon: component to show polygons
- TGMRectangle: component to show rectangles
- TGMCircle: component to show circles
Compiled in:
- Delphi 6
- Delphi 7
- Delphi 2007
- Delphi 2010
- Delphi XE2
More information (spanish only, but you can translate it )
Download
WPTools v6.25.4 Standard Edition + Manuals (for Delphi 5-XE2)
12.3.2012 - WPTools 6.25.4
* allows changing of column width in redonly editors. Can be switchoed off in EditOptions or set
compiler define TOTALREADONLY
+ wpDisableSelectAll in EditOptionsEx2
* changed reformat/repaint after Undo/Redo
- pro and premium: Due to a problem with precompiler cursoir selection did not work correctly
Thanks for your links...
Добавлено через 11 минут
Thank you for your help...
Very nice :)
