thank you ...
Добавлено через 46 секунд
ooops ... sorry for the error ...
TMS Component Pack 6.5.0.0 for Delphi & C++Builder 5-XE3 Full Source
Thanks to DarkRapt0r
Code:
Create modern-looking & feature-rich Windows applications faster with over 300 components in one money and time saving bundle.
TMS Component Pack for Delphi & C++Builder includes feature-packed grids, Office 2007 ribbon, Office 2003 style toolbar, planning/scheduling components, advanced edits, toolbars, internet auto application update, Office 2003/2007 style tabs, pager, panel, Outlook navigational controls and much much more...
Source Setup:
Code:
Demos Setup:
Code:
Password:
Code:
TMSSux
NO mirrors, NO repacks
\\ DarkRapt0r
Demos Setup: Как увидеть ссылки? | How to see hidden links?
Password: TMSSux
All links are dead. Can someone post a mirror please!
Добавлено через 1 минуту
Castalia 2012.3
Castalia 2012.3 for Delphi 5-XE3
Code:
Castalia transforms the Delphi programming environment into an amazing development platform.
Castalia lives on the bleeding edge of IDE technology, giving you cutting edge tools to write better code faster, understand code more accurately, and improve code you've already written.
AIO Setup:
Code:
\\ DarkRapt0r
Berg Soft Components. New version (September) 09.2012 Delphi 7 - XE2
FULL SOURCE
Sep 5 2012
NextGrid, NextDBGrid v5.7.1
added: TNxHtmlColumn now support IMG tag and SRC parameter. JPG and BMP images are supported.
fixed: Bug fixes and internal tweaks.
NextInspector v5.7.1
fixed: TNxCheckBoxItem bug with MapProperty connected to string property.
NextSheet v5.7.1
changed: When Enabled is set to False, Selection is not drawn.
32 mirrors.
Как увидеть ссылки? | How to see hidden links? (12 mirrors)
Как увидеть ссылки? | How to see hidden links? (10 mirrors)
Как увидеть ссылки? | How to see hidden links? (11 mirrors)
Free Cindy v5.08 with XE3 support released!
Cindy Pack Components list:
- TcyBevel: multi colored bevels.
- TcyPanel: runtime resize feature, multi colored bevels, gradient and shadow feature.
- TcyAdvPanel: like TcyPanel plus wallpaper feature.
- TcyPaintbox: multi colored bevels, gradient.
- TcyAdvPaintBox: like TcyPaintBox plus wallpaper feature.
- TcyLabel: caption orientation, gradient, shadow and indent caption.
- TcyHotLabel: like TcyLabel with different views for each component state (like mouse hover).
- TcySpeedButton: colored speedButton with lot of features like jpeg/png glyph, imagelist option.
- TcyAdvSpeedButton: Like TcySpeedButton with different views for each component state (like mouse hover).
- TcyBitBtn: colored BitBtn with lot of features like jpeg/png glyph, imagelist option.
- TcyAdvButton: Like tcyBitBtn with different views for each component state (like mouse hover).
- TcySkinButton: non rectangular button with an image for each state.
- TcySkinArea: create multiple non rectangular buttons in a single component with different states for exemple a virtual keyboard.
- TcyLed: simple led with multi-colored feature and shape.
- TcyAdvLed: a Led with a picture for each state.
- TcySimpleGauge: a gauge with (float precision) orientation feature, transparency and personalizable view.
- TcySplitter: advanced splitter gradient background, grip and wallpaper features. Can move/resize its parent control.
- TcyColorMatrix: 2 dimensions colors grid representation, very fast.
- TcyColorGrid: pick a color from the list. Totally personalizable.
- TcyStatusBar: StatusBar that accept controls at design time.
- TcyBook: See images in a virtual book with turn page effect and pages handling.
- TcyIniForm: save your users size and position form without code in file or registry, allows custom load/save information.
- TcySearchFiles: retrieve files from directory with a lot of options like file mask/file exclude mask etc ... you can also pause/resume or abort, has a lot of events to personalize.
- TcyCopyFiles: herited from TcySearchFile, use it to copy files.
- TcyFlyingContainer: show any control in front of others (in a floating form) and hide it when it lose focus.
- TcyModalContainer: show any control in a Modal form.
- TcyResizer: move and resize components at run-time like delphi 2009 does, very easy to use.
- TcyVirtualGrid: create a virtual grid, see demo program.
- TcyProgressionPanel: show a animated panel information on blocking long process with determined several steps. Cancel button feature.
- TcyAdvProgressionPanel: show a threaded animated panel information on undetermined time blocking single process.
- TcyCommRoomConnector: create/connect to an in memory virtual room for TcyBaseComm base components (like TcyCommunicate) to be seen and communicate each other. with each other.
- TcyCommunicate: allows communication between applications running in same computer session.
- TcyAppInstances: avoid application (or a group of application) multiple instances. You can also catch passed parameters.
- TcyRunTimeResize: move and resize a single component at run-time.
- TcyClipboard: handle clipboard formats.
- TcyDDECmd: open/register an extension for your application.
- TcyMathParser: parse matematical expressions.
- TcyDebug: check code entering/leaving ocurrances, speed and average by adding tags on your code.
- TcyDBLabel: DB Control herited from TcyLabel.
- TcyDBHotLabel: DB Control herited from TcyHotLabel.
- TcyDBEdit: TDBEdit with embedded parser feature.
- TcyDBLed: DB control herited from TcyLed.
- TcyDBAdvLed: DB control herited from TcyAdvLed.
- TcyDBRadioButton: DB control herited from TRadioButton.
- TcyDBSpeedButton: DB control herited from TcySpeedButton.
- TcyDBAdvSpeedButton: DB control herited from TcyAdvSpeedButton.
- TcyDBSimpleGauge: DB control herited from TcySimpleGauge.
- TcyDBGrid: advanced DBGrid with lot of features (checkboxes for each record, auto client column, multi-record selection made easy etc ...)
- TcyDBAdvGrid: based on TcyDBGrid, added gradient, embedded graphic/memo fields rendering etc ...
- TcyBookmarks: bookmark records with this independant bookmark list.
- TcyFieldLink: connect a non DB Control (for exemple a TDateTimePicker) to a field.
Cindy Internet Explorer component list:
- TcyWebBrowser: Herited from TWebBrowser, allows easy load/save/edit html documents.
Cindy Document Element Recognizer component list:
- TcyDocER: extract document information (mail, phone, amounts etc ...) using OCR results from any source like Tesseract (open source) or Transym (comercial but cheap, fast, easy and powerful).
Cindy DB Express component list:
- TcyDBXSQLUpdate: based from DBExpress components, it allows easy table creation/modification etc ...
- TcyDBXTable: based from DBExpress components, allows automatic server side updates in order to simplify SQL table records handling.
The goal is to reproduce BDE TTable component behavior: no worry with server side updates/refresh.
- TcyDBXReconcileError allows reconcile error definitions/handling. You can attach a TcyDbxReconcileError to one or more TcyDbxTables.
- TcyDBXImportDataset Create/ alter SQL table based on attached TDataset or directly filling Fields property.
Go to Как увидеть ссылки? | How to see hidden links? for weekly updates and news.
eXcEl3rator
eXcEl3rator is a RAD Studio XE3 Architect Memory Manager replacement with a side effect that may come in handy.
I'm sure you know what I'm talking about
Code:
Password:
Code:
XE3
\\ DR
