FastReport Enterprise Edition v4.14.1 Full Source
+ Added Embarcadero RAD Studio XE4 support
- [Lazarus] fixed bug with text output
- [Lazarus] fixed bug with some visual controls in designer
- [Lazarus] improved interface of the report preview and designer
- [Lazarus] fixed bug with boolean propertyes in script code and expressions
- fixed bug with endless loop in TfrxRichView
- fixed bug with Unicode in TfrxMemoView appeared in previous release
- improved MAPI interface in TfrxExportMail export
- fixed some problems with allpication styles XE2/XE3
- improved compatibility with Fast Report FMX
Добавлено через 1 минуту
EMS Advanced Excel Report v1.9.2.1 D5 - XE4 Full Source
Advanced Excel Report for Delphi is a powerful band-oriented generator of template-based reports in MS Excel. Easy-to-use component property editors allow you to quickly create powerful reports in MS Excel. Now you can create reports, which can be edited, saved to file and viewed almost on any computer.
Key Features
Creating report templates directly in MS Excel
Saving template as in the external *.xls file, as in the *.dfm (.exe) file
Band-oriented report generator
Any data source can be used
Creation of master-detail reports and reports with grouping
Full integration with Delphi IDE
High productivity even on slow computers
Detailed help system and a demo application for a quicker mastering of the product
Powerful component and property editors, which allow you to set many report parameters at the design-time easily
Delphi 5-7, 2005-2007, 2009, 2010, XE, XE2, XE3, XE4 and MS Office 97 SR-1, 2000-2010 support
Key Features
