Magix Audio Cleaning Lab
Всёравно такая фишка:
Mon Jul 19 23:23:24 2004 Соединение с ftp2.ttdown.com:8080
Mon Jul 19 23:23:24 2004 Соединяемся с ftp2.ttdown.com [IP=61.133.108.7:8080]
Mon Jul 19 23:23:24 2004 Соединение установлено
Mon Jul 19 23:23:24 2004 GET /8oSA/2004/07B/Magix%20Audio.Cleaning.Lab.2005.v5.01.CR.exe HTTP/1.1
Mon Jul 19 23:23:24 2004 Host: ftp2.ttdown.com:8080
Mon Jul 19 23:23:24 2004 Accept: */*
Mon Jul 19 23:23:24 2004 Referer: Как увидеть ссылки? | How to see hidden links?
Mon Jul 19 23:23:24 2004 User-Agent: Mozilla/4.0 (compatible; MSIE 5.00; Windows 98)
Mon Jul 19 23:23:24 2004 Pragma: no-cache
Mon Jul 19 23:23:24 2004 Cache-Control: no-cache
Mon Jul 19 23:23:24 2004 Connection: close
Mon Jul 19 23:23:26 2004 HTTP/1.1 403 Access Forbidden
Mon Jul 19 23:23:26 2004 Server: Microsoft-IIS/5.0
Mon Jul 19 23:23:26 2004 Date: Mon, 19 Jul 2004 19:23:42 GMT
Mon Jul 19 23:23:26 2004 Connection: close
Mon Jul 19 23:23:26 2004 Content-Length: 4155
Mon Jul 19 23:23:26 2004 Content-Type: text/html
Mon Jul 19 23:23:26 2004 Ошибка!
Mon Jul 19 23:23:26 2004 Пауза 10 сек. перед повтором
Mon Jul 19 23:23:36 2004 Соединяемся с ftp2.ttdown.com [IP=61.133.108.7:8080]
Mon Jul 19 23:23:36 2004 Соединение установлено
Mon Jul 19 23:23:36 2004 GET /8oSA/2004/07B/Magix%20Audio.Cleaning.Lab.2005.v5.01.CR.exe HTTP/1.1
Mon Jul 19 23:23:36 2004 Host: ftp2.ttdown.com:8080
Mon Jul 19 23:23:36 2004 Accept: */*
Mon Jul 19 23:23:36 2004 Referer: Как увидеть ссылки? | How to see hidden links?
Mon Jul 19 23:23:36 2004 User-Agent: Mozilla/4.0 (compatible; MSIE 5.00; Windows 98)
Mon Jul 19 23:23:37 2004 Pragma: no-cache
Mon Jul 19 23:23:37 2004 Cache-Control: no-cache
Mon Jul 19 23:23:37 2004 Connection: close
Mon Jul 19 23:23:38 2004 HTTP/1.1 404 Object Not Found
Mon Jul 19 23:23:38 2004 Server: Microsoft-IIS/5.0
Mon Jul 19 23:23:38 2004 Date: Mon, 19 Jul 2004 19:23:54 GMT
Mon Jul 19 23:23:38 2004 Connection: close
Mon Jul 19 23:23:38 2004 Content-Length: 4155
Mon Jul 19 23:23:38 2004 Content-Type: text/html
Mon Jul 19 23:23:38 2004 Ошибка!
Neon2, а правила закачки с китайских сайтов соблюдаешь?
2004-07-20 06:32:25.175 Соединение с ftp2.ttdown.com:8080
2004-07-20 06:32:34.690 Соединение с 61.133.108.7:8080
2004-07-20 06:32:40.081 Соединение установлено
2004-07-20 06:32:40.081 GET /BCW4/2004/07B/Magix%20Audio.Cleaning.Lab.2005.v5.01.CR.exe HTTP/1.1
2004-07-20 06:32:40.096 Host: ftp2.ttdown.com:8080
2004-07-20 06:32:40.128 Accept: */*
2004-07-20 06:32:40.128 User-Agent: Mozilla/4.0 (compatible; MSIE 5.00; Windows 98)
2004-07-20 06:32:40.128 Range: bytes=871088-84550566
2004-07-20 06:32:40.143 Connection: Keep-Alive
2004-07-20 06:32:45.971 HTTP/1.1 206 Partial content
2004-07-20 06:32:45.971 Server: Microsoft-IIS/5.0
2004-07-20 06:32:45.971 Date: Mon, 19 Jul 2004 19:33:22 GMT
2004-07-20 06:32:45.971 Content-Type: application/octet-stream
2004-07-20 06:32:45.971 Last-Modified: Sat, 17 Jul 2004 17:47:26 GMT
2004-07-20 06:32:45.971 ETag: "5c247b1f266cc41:1753"
2004-07-20 06:32:45.971 Content-Length: 83679479
2004-07-20 06:32:45.971 Content-Range: bytes 871088-84550566/84550567
2004-07-20 06:32:45.987 Начат прием данных
это последний раз, остальное буду считать флудом
147!
Не могу найти на странице ссылку на сам файл для закачки. Китайский у меня стоит. Подскажи, где эта ссылка на этой странице. Уже и так и эдак пытался, не могу найти ссылку для закачки. Или скрин прислать с вопросом?
Wed Jul 21 00:09:19 2004 GET /SoftView/SoftView_24376.htm HTTP/1.1
Wed Jul 21 00:09:19 2004 Host: soft.ttdown.com
Wed Jul 21 00:09:19 2004 Accept: */*
Wed Jul 21 00:09:19 2004 Referer: Как увидеть ссылки? | How to see hidden links?
Wed Jul 21 00:09:19 2004 User-Agent: FlashGet
Wed Jul 21 00:09:19 2004 Pragma: no-cache
Wed Jul 21 00:09:19 2004 Cache-Control: no-cache
Wed Jul 21 00:09:19 2004 Connection: close
Wed Jul 21 00:09:20 2004 HTTP/1.0 404 Not Found
Wed Jul 21 00:09:20 2004 Server: Microsoft-IIS/5.0
Wed Jul 21 00:09:20 2004 Date: Tue, 20 Jul 2004 22:10:02 GMT
На самом деле чего флудить ... Отключите нафик файрволы .. Заходите на китайскую страничку и оттуда качайте ... Все работает !
Не обязательно в один поток... вчера стянул в пять потоков и нормально тянулось по всем пяти... На счет того что не качает... у меня только после 30 попытки был конект
При нормально настороенном фаерволе отключать ничего не надо, иначе зачем он нужен. Но я уже два дня пытаюсь тянуть как положено в один поток Гетом, и не идет.Причём выпадает из закачки после нескольких попыток. Может дело во времени закачки?
[ADDED=Arck]1090399237[/ADDED]
Оказывается ссылка немного изменилась. Скажем дружное сенкс 147 за уточнённый адресочек. Качаем отсюда FlashGet ом в один поток
_http://ftp2.ttdown.com:8080/BCW4/2004/07B/Magix%20Audio.Cleaning.Lab.2005.v5.01.CR.exe
@lex сказал(а):
Нужно качать флешгетом и в один поток.
147 сори не заметил :(
Я давным-давно юзаю DM. Вопрос такой - флашгет обязателен?
Все, по новой ссылке поехало...
2 Arck - спасибо! По исправленной ссылке у меня тоже сразу стало качаться.
2 147 - Не надо думать что народ тут тупой, все правила закачки я соблюдал, но в итоге получал ошибку 404. Сенкс за наконец-то рабочую ссылочку.
Да, Гетом обязательно, Dm не тянет те файлы которые тянет Гет. Не вдавался в детали и не знаю с чем это связано. Но то, что это так, гарантирую. Сам проверял.
[ADDED=Arck]1090437362[/ADDED]
Ребятки, не наезжайте на 147! Он совершенно бескорыстно делает работу, которая далеко не всем под силу. Давайте лучше скажем ему СПАСИБО! Ведь ссылку ОН уточнил, я это только разместил. Ну не может человек уследить за всеми линками. А разница была в 2-3 буквах, не мудрено ошибиться.
Arck, спасибо за понимание, а на счёт ссылок, моей ошибки нет, там просто адреса ссылок меняют и именно по этому я даю страничку для обновления их, а тем кто выражает недовольство я просто не отвечаю (мало того, что не читают, так ещё и недовольство выражают)
вот по новой ссылке все стало качаться!!!! Ура!!!!
И сенкс за исправления!!!!
flash тянет, а вот DM новую ссылку дергать не пробовал
Сдохла ссылка. Обновите еще раз, плиииз! :)
