-New: Global VM - almost revolutionary new way how to write VM script. Modal-less window (like lab-Talk). One, place for all the objects. Comments in code. Automatic GPRM partioning, Aliases, IF-THEN-ELSE and Goto by labels. Link/Jump/Call by Object name. Hardcore DVD nerds heaven.
Please check the Help 2.0 online Global VM Section
-Fix: Displaying VM command in connection was broken if VM command had OR operator.
-Fix: Override Aspect Ratio in VTS will not change aspect ratio of Cells, same when loading.
-Fix for some players 2xFF and REW problem (ADT is now set as ROM, before it has been set as R/RW which may cause on some old players to simply disable 2xFF/REW - courtesy of DVD specs)
-Fix: Combo-Buttons didn't work correctly with new Enhanced menu rendering introduced in 2.2
-Fix for stuttering bug on long movies after certain time
-Clone Mega-Project (Save As... in mega project didn't work as expected - now it will Clone whole Mega-Project into new directory.
- Time map unit fix - time map will not exceed 2048
- Slideshow Muxer adjustement
