Photoshop plugins, часть 2
DOF PRO v4.0.28 for Adobe Photoshop
DOF PRO is the result of ongoing research, development and programming collaboration between Richard Rosenman and Martin Vicanek in an effort to produce a Photoshop« compliant plugin capable of delivering high quality sophisticated Depth of Field and Bokeh effects quickly and efficiently as a post process.
Depth of field (DOF) is the amount of distance between the nearest and furthest objects that appear in acceptably sharp focus as seen by a camera lens. This field varies with the focal length of the lens, its f-stop setting, and the object distance from the camera.
INSTALLATION
Go to install directory, copy "dofpro.8bf" & "dofpro.lic" into your photoshop/plugins directory.
The plugin is already cracked.
3306 KB
Humansoftware Styles FX vol. 1
Humansoftware Styles FX vol. 2
Humansoftware Styles FX vol. 3
HumanSoftware TEXTISSIMO v3.21
With Textissimo get more than 700 text effects on Windows or Mac OS X that run Photoshop Plug-Ins and features:
- more than 700 ready made effects for your web!
- beautiful blends on all your images
- apply your effects on text, shapes...perfect for buttons!
- customise your own effect, a ton of fun, essential for a designer!
- Choose from more than 700 Libraries - and create amazing effects for your day-to-day jobs/projects/web sites - Vignettes, Advanced Gradients, Drop Shadows, Textures inside Type...
Реакции: arka
HumanSoftware MagicFrames 2.03
HumanSoftware PhotoSurface v.3.02
С помощью этого фильтра для Adobe Photoshop и Corel PhotoPaint можно получить более 300 реалистичных эффектов текстур. таких как железо, дерево, камень, бумага и кожа. Также имеются погодные эффекты.
Благодаря настраиваемому механизму расположения слоев, нет ограничений на количество добавляемых поверхностей/текстур.
• 300 ready made textures or surface for all your images!
• Create and record your very own setting for your own surface
• Many Natural Textures : wood/rocks/metal/leather/paper...
• Use any Image as a basic tile to your new Surface
• Angle and adapt the Surface to the new overlay Grain
• Render Aging and Distress effects
HumanSoftware IniCaps v.1.0
Набор красивых рисунков букв
IniCaps are not fonts. Each Cap is a high-resolution image, that can be resized to adjust your design need : brochure, postcard, web-page. Initial Caps from the IniCaps collection will work smoothly inside Microsoft Word, Quark XPress, Adobe PageMaker or Illustrator, Macromedia Freehand or DreamWeaver, Corel Draw, Adobe Go-Live, Photoshop etc...
HumanSoftware AutoDeNoise v.1.8
Плагин для уменьшения шума на изображениях.
AutoDeNoise is an effective and very affordable solution for the amateur/ hobbyist or the professional portrait photographer to bring the best of their subjects. to reduce visible noise and grain in photographic images produced by digital cameras and scanners. AutoDenoise is very efficient in low-light (indoors, night, astro) and high-speed (sport, action) photography.
HumanSoftware PhotoSpray v.1.5.4 vol. 1-4
Действует по принципу кисти, только вместо мазка выплескиваются выбранные наборы картинок.
HumanSoftware PhotoPatch v1.5
* 200 ready made Patchwork/Weave/Mosaic for all your images!
* Create and record your very own setting for your own effect
* Effects impossible to achieve with any other methods...
* Use any Image as a basic spray to a new Mosaic Effect
* Use Any PatchWork/Mosaic/Weave through masks to create dramatic frames
Human Software PhotoWeave v.1.5
•Create your own Plaids or Strip Fabric in a snap
•Up to 16 yarns in the Weft and Warp direction
•You can combine fabrics and simulate very sophisticated weaving
•Fashion designer, create your own fabric, super realistic effect, amazing results are guaranteed and tons of fun!!!
HumanSoftware Magic Styles 1.5
HumanSoftware MagicStyles is like a full featured illustration tools directly inside Photoshop/Elements/Paintshop and more plus a unique set of effects like images stroke along a path, images fills, shadows...
1- Users can now create basic vector shapes that can be filled and stroked, as well as text on a path, MagicStyles features an extremely powerful text warping that can be edited at any time..
2 - Users can choose to Flow a Text on a Path (reediting is possible even after rasterization) create Stars, Rounded rectangles, polygons and more...
3- All Paths and Tracks are now ready for new effects, and MagicStyles really shines here (users are not limited to a simple tint or opacity change!)!
3- MagicStyles offers hundreds of original effects, that you can combine at once, thanks to its layering mecanism. Yes MagicStyles has layers within a plug-in, and this is dramatically powerful...
OnOne Software PhotoTools Professional Edition v2.0
предлагает целый набор качественных спецэффектов, инструментов для коррекции и редактирования снимков, а также средства автоматизации творческого процесса, объединенные удобным и функциональным интерфейсом. Высококачественные фильтры могут использоваться для обеспечения цветокоррекции и поляризации изображения. С помощью предлагаемых инструментов фотомастера смогут осуществить стилизацию цифровых снимков под старые фотографии или кадры кинопленки. В окне предварительного просмотра можно увидеть действие каждого из полутора сотен эффектов PhotoTools перед его применением. К каждому изображению можно применить одновременно несколько эффектов, также допускается возможность пакетной обработки фотоснимков. Излюбленные комбинации эффектов могут быть сохранены в отдельный файл.
Как и все onOne программных продуктов, PhotoTools 2 является простым в использовании, с современным пользовательским интерфейсом и дружественным контролем. Вы можете начать улучшать изображения сразу с нескольких кликов. Чтобы помочь вам стать мастером в использовании даже самых передовых возможностей есть более десятка встроенных видео-учебников и удобная система поиска поможет найти то что вам нужно .
Новое в PhotoTools 2
Фотографические эффекты
Поддержка Adobe Photoshop Lightroom и Apple Апертура
Фотографы могут теперь использовать PhotoTools 2 Professional Edition внутри Lightroom 2 и Диафрагма2.1. Маскирование контроля
Поддержка видео
Фотографы могут теперь использовать PhotoTools 2 для коротких видеоклипов внутри Photoshop CS3 Extended и Photoshop CS4
Дополнительные Аксессуары
Есть много других дополнительных аксессуаров к PhotoTools 2, с улучшением качества обслуживания пользователей и сделать его более приятным для вас, в том числе:
- Улучшена поддержка для записи действий
- Улучшение памяти для работы на больших изображениях
- Быстрее превью с аксессуарами с поддержкой OpenGL
- Прозрачные регионы лучше сохранять для использования в рабочих форматах альбома
- Улучшенная поддержка управления цветом
- Новое руководство пользователя для поиска и усовершенствованные видео-учебники
Операционная система: Windows XP/Vista.
Язык интерфейса: Английский
Лекарство в архиве
Скачать с Rapidshare.com
Mask Pro 4.1.2 - Full Version
Mask Pro 4.1 is the premiere, award-winning plug-in for masking in Photoshop. The latest version of Mask Pro 4.1 supports masking 8-bit and 16-bit digital images in both Photoshop CS2 and Photoshop CS3. Several new "Show Me How" video tutorials are built directly into Mask Pro 4.1 so you can get visual training quickly. No other masking or selection tool gives you the professional level results like Mask Pro 4.1.
Добавлено через 7 минут
PhotoTune 2.2 - Full Version
PhotoTune 2.2 is an Adobe® Photoshop® plugin that provides professional quality color correction in an easy to use plug-in. PhotoTune 2.2 incorporates ColorTune technology (formerly known as 20/20 Color MD) with its patented color correction process and SkinTune technology, developed after more than two years of in-depth skin color research. PhotoTune 2.2 makes the tedious and time-consuming task of color correction simple and straightforward to improve your post-processing workflow.
onOne Plug-In Suite v4.5
Компания onOne Software выпустила пакет своих плагинов Plug-In Suite 4.5 для Photoshop. Все дополнения, которые входят в этот пакет, поддерживают Photoshop СS4.
Genuine Fractals 6 Professional Edition
Плагин предназначен для увеличения размера изображений до 1000% практически без потери качества. Genuine Fractals 6 дает лучшие результаты, чем стандартные методы масштабирования, которые используются в Photoshop.
Шестая версия Genuine Fractals поддерживает Photoshop CS4. Кроме этого, в плагине переработан интерфейс, добавлена поддержка многопроцессорных систем, добавлена поддержка Actions, появились новые шаблоны для быстрой обрезки и изменения размера изображений, новые настройки для контроля за детализацией рисунка, резкостью и наличием "зерна". Также плагин теперь поддержвает изменение размера изображений в файлах Photoshop, которые содержат несколько слоев, в том числе нерастрированные текстовые слои, "умные" объекты, альфа-каналы и пр.
PhotoTools Professional Edition предлагает целый набор качественных спецэффектов, инструментов для коррекции и редактирования снимков, а также средства автоматизации творческого процесса, объединенные удобным и функциональным интерфейсом.
Высококачественные фильтры могут использоваться для обеспечения цветокоррекции и поляризации изображения. С помощью предлагаемых инструментов фотомастера смогут осуществить стилизацию цифровых снимков под старые фотографии или кадры кинопленки.В окне предварительного просмотра можно увидеть действие каждого из полутора сотен эффектов PhotoTools перед его применением. К каждому изображению можно применить одновременно несколько эффектов, также допускается возможность пакетной обработки фотоснимков. Излюбленные комбинации эффектов могут быть сохранены в отдельный файл.
Mask Pro 4.1
Предназначен для вырезания объектов с фотографий и переноса в другое окружение. Плагин Mask Pro предоставляет в распоряжение дизайнера полный набор интуитивных и удобных инструментов для маскирования объектов и использует технологии, позволяющие максимально точно сохранить цвета и произвести очистку краев объекта. Новая версия получила поддержку планшетов Wacom. В комплект новой версии войдут встроенные видеоучебники и сборник советов. Mask Pro 4.1 будет отображать в панелях инструментов цифровые эквиваленты значений органов настройки, при необходимости производить автоматическую прокрутку изображения, а новая палитра позволит пользователю точно определить выделяемые цвета.
PhotoFrame 4 Professional Edition
Это дополнение предназначено для создания рамок и дает возможность создавать практически любые обрамления – объемные, со свечением, с использованием текстур, отбрасывающие тени и т.д.
Главное нововведение последнего релиза – поддержка Photoshop CS4. Кроме этого, появилась опция автоматического вращения, которая определяет горизонтальную или вертикальную ориентацию фотографий и поворачивает рамки так, чтобы они как можно лучше накладывались на изображения.
PhotoTune 2.2
В состав этого модуля входит два отдельных компонента - ColorTune 2.0 и SkinTune 2.0.
ColorTune представляет собой универсальное решение для коррекции цифровых снимков. Плагин работает в виде пошагового мастера, на каждом этапе работы которого пользователю предлагается выбрать более удачный вариант исправленной картинки из двух вариантов.
SkinTune – это плагин, позволяющий устранить на портретах недостатки, связанные с некорректным освещением. Его уникальность в том, что он учитывает цвет кожи. При одном и том же освещении кожа разного цвета будет освещена по-разному. Если сфотографировать двух людей с разным цветом кожи в одних и тех же условиях, одна фотография может оказаться удачнее другой.
(Для начала работы SkinTune обязательно нужно указать, к какой расе принадлежит человек на портрете, а затем выбрать на лице неудачный участок - слишком затененный или слишком осветленный. Основываясь на этой информации, фильтр подберет оптимальный баланс света на изображении и придаст коже естественный оттенок.)
FocalPoint 1.1
Дополнение предназначено для создания виньеток и добавления на изображение эффекта фокуса. Такой эффект очень популярен, в частности, в свадебной и портретной съемке – в фокусе остается только главный объект, а все вокруг размывается. В FocalPoint есть много возможностей для создания разных эффектов такого рода: можно имитировать эффект смаза при движении, затемнять или осветлять участки изображения, которые не попали в фокус и т.д. Плагин поддерживает сохранение созданных с его помощью эффектов в виде шаблонов для многократного использования в дальнейшем.
Год выпуска: 2009
Разработчик: Как увидеть ссылки? | How to see hidden links?
Совместимость с Vista: полная
Лекарство: Присутствует
Формат: RAR, ISO
1. Распаковать архив
2. Смонтировать ISO-образ в Daemon Tools или Alcohol
3. Установите onOne Plug-In Suite v4.5
4. Откройте ISO-образ и найдите папку GRB(там кейген).
5. Запустите License Manageruse(*:\Program Files\onOne Software\Plug-in Suite 4\License Manager.exe). Выберите активацию по телефону и используя кейген активируйте onOne Plug-In Suite v4.5!
[I][B]RapidShare[/B][/I]
http://rapidshare.com/files/209691581/oOPISv4.5.part01.rar
http://rapidshare.com/files/209686533/oOPISv4.5.part02.rar
http://rapidshare.com/files/209783325/oOPISv4.5.part03.rar
http://rapidshare.com/files/209945918/oOPISv4.5.part04.rar
http://rapidshare.com/files/209867447/oOPISv4.5.part05.rar
http://rapidshare.com/files/209880077/oOPISv4.5.part06.rar
http://rapidshare.com/files/210197333/oOPISv4.5.part07.rar
http://rapidshare.com/files/210199779/oOPISv4.5.part08.rar
http://rapidshare.com/files/210211915/oOPISv4.5.part09.rar
http://rapidshare.com/files/210211815/oOPISv4.5.part10.rar
http://rapidshare.com/files/210224279/oOPISv4.5.part11.rar
http://rapidshare.com/files/210224397/oOPISv4.5.part12.rar
http://rapidshare.com/files/210238710/oOPISv4.5.part13.rar
http://rapidshare.com/files/210238604/oOPISv4.5.part14.rar
http://rapidshare.com/files/210252911/oOPISv4.5.part15.rar
http://rapidshare.com/files/210252910/oOPISv4.5.part16.rar
http://rapidshare.com/files/210272979/oOPISv4.5.part17.rar
http://rapidshare.com/files/210272815/oOPISv4.5.part18.rar
http://rapidshare.com/files/210289475/oOPISv4.5.part19.rar
http://rapidshare.com/files/210289450/oOPISv4.5.part20.rar
http://rapidshare.com/files/210305627/oOPISv4.5.part21.rar
http://rapidshare.com/files/210305819/oOPISv4.5.part22.rar
http://rapidshare.com/files/210318366/oOPISv4.5.part23.rar
http://rapidshare.com/files/210310086/oOPISv4.5.part24.rar
[I][B]DepositFiles[/B][/I]
http://depositfiles.com/files/lyv361enm
http://depositfiles.com/files/7af7ba621
http://depositfiles.com/files/5j00rkngv
http://depositfiles.com/files/qlrnpfak3
http://depositfiles.com/files/2yn575gaj
http://depositfiles.com/files/u0lkg3b7y
http://depositfiles.com/files/iqn01q051
http://depositfiles.com/files/gjoron2fa
http://depositfiles.com/files/ekm5id0dl
http://depositfiles.com/files/v9itwbma3
http://depositfiles.com/files/yfe67bxa3
http://depositfiles.com/files/js9isip85
http://depositfiles.com/files/nt1ze498j
http://depositfiles.com/files/7krcr3u1i
http://depositfiles.com/files/jti75wtlf
http://depositfiles.com/files/u329bq1xt
http://depositfiles.com/files/ptqz191ow
http://depositfiles.com/files/8r1yxemr4
http://depositfiles.com/files/vf690tl36
http://depositfiles.com/files/d9b0rvb3u
http://depositfiles.com/files/inhi6qk5m
http://depositfiles.com/files/0g78fhvmz
http://depositfiles.com/files/x51sde4yw
http://depositfiles.com/files/mfils3oey
[U]Пароль:[/U]
[url]http://10bit.ru/[/url]
а чем оно отличается от предыдущей?
AKVIS Sketch v. 7.0 + Manual_RU
Новая версия плагина, "превращающего" любое фото в карандашный рисунок. Универсальный ретриалер в комплекте.
Noise Ninja v2.1.2
- это очень мощная программа для подавления цифрового шума. Она является лидером в своем классе и по получаемым результатам с ней могут сравниться лишь Neat Image и Grain Surgery. Эффективное и производительное решение для устранения зерна и помех с цифровых фотографий или сканера. Эффект применения Noise Ninja воистину волшебен: шум во всех своих проявлениях ослабляется или даже исчезает без следа, в то время как потеря деталей и насыщенности некоторых цветов сведена практически к минимуму.
Работа Noise Ninja основана на профилях, которые создаются не только для различных камер, но и для разных параметров съемки этими камерами. Программа имеет функцию автоматического профилирования камеры как на основе обрабатываемой фотографии, так и на основе снимков специальной мишени, оптимизированный для создания шумовых профилей. В момент загрузки изображения для обработки, Noise Ninja считывает EXIF информацию из файла и на основании параметров съемки автоматически подбирает и подгружает наиболее подходящий профиль для подавления цифрового шума.
Операционная система: Windows 2000/XP/Vista.
Дом. страница: http://www.picturecode.com/
В архиве:
1) Самостоятельная (автономная) версия
2) Плагин для Adobe Photoshop.
11.09 MB
Реакции: KGN
Pixplant v2.0.43 and Pixplant For Photoshop v2.0.43​
Pixplant - программа представляет из себя инструмент для создания высококачественных бесшовных текстур из фотографий. Утилита реализована в виде отдельной программы и в виде плагина для Adobe Photoshop. Поможет вам создавать бесшовные текстуры любого размера на основе каких-либо фотографий и изображений. При создании текстуры можно указывать, должна ли она быть бесшовной по горизонтали и/или по вертикали, исключать из процесса генерации некоторые части исходного изображения, задавать повторяемость и прочее. Вы можете сохранить множество времени благодаря использовании технологии применяемой в программе, которая за четыре клика создаст бесшовную текстуру.
Преимущества:
» Быстрое создание уникальных бесшовных текстур
» Исходя из реальных фотографий, программа создает реалистичные текстуры без каких-либо искажений
» Позволяет генерировать не повторяющиеся текстуры
» Создание текстур в высоком разрешении и качестве из исходного изображения
» И многое другое...
Особенности:
» Создание текстуры практически из любой фотографии, благодаря продвинутой технологии выпрямления
» Высокая автоматизация задач
» Большинство текстур создается за 1-4 клика
» Тщательно продуманный и простой в использовании интерфейс с интерактивной справкой и полноэкранным предпросмотром
» Используется в качестве отдельной программы и в качестве плагина для Adobe Photoshop
Дом. страница: http://www.pixplant.com/index.php
Pixplant v2.0.43
7.11 MB
7.2 MB
Реакции: KGN
Для Astrall
Скачал с Депозита onOne Plug-In Suite v4.5. При разархивировании 23 части появилось сообщение, что для этой части пароль ошибочный. Скачал эту часть с зеркала, ошибка та же. Попыталя с рапиды, что-то не получилось, закачиваю снова, боюсь как бы все не повторилось. Можно перезалить эту часть на Депозит?
