thanx alot anickolsky!
I use jdk-6u31-windows-i586
I had try for several times,error occurs everytime.
form "PTCSOLNINSTALLER_InstallLog.xml":
com.ptc.windchill.install.suite.WindchillDDLManager" target="com.ptc.windchill.install.suite.WindchillDDLManager" status="success" />
</InstallLogDetails>
</InstallationLog>
It seems it is ok
But after it appears "Windchill Loader failed "
from "PTCSOLNINSTALLER_PtcInstall.log":
DEBUG 2012-04-17 20:21:51 - apache appears to be down. Starting it...
DEBUG 2012-04-17 20:21:51 - Executing: cmd.exe /C set SystemRoot
DEBUG 2012-04-17 20:21:51 - Starting Apache with: C:\Windows\system32\cmd.exe /C start "Apache f:\ptc\Windchill\Apache" /MIN C:\Windows\system32\cmd.exe /C f:\ptc\Windchill\Apache\bin\httpd.exe -f f:\ptc\Windchill\Apache\conf\httpd.conf
DEBUG 2012-04-17 20:21:51 - Executing: C:\Windows\system32\cmd.exe /C start Apache f:\ptc\Windchill\Apache /MIN C:\Windows\system32\cmd.exe /C f:\ptc\Windchill\Apache\bin\httpd.exe -f f:\ptc\Windchill\Apache\conf\httpd.conf
DEBUG 2012-04-17 20:21:52 - socket connect to localhost:80 completed with no error
DEBUG 2012-04-17 20:21:52 - Checking if web service is running...
DEBUG 2012-04-17 20:21:52 - checking URL connection to
Как увидеть ссылки? | How to see hidden links? ...
DEBUG 2012-04-17 20:21:52 - apache running at
DEBUG 2012-04-17 20:21:52 - Apache seems to be running.
INFO 2012-04-17 20:21:52 - Loader command: F:\ptc\Windchill\Windchill\bin\windchill.exe --java=C:\Java\jdk\bin\java.exe --javaargs=-Dwt.load.installer.serverManagerTimeout=300 wt.load.WindchillLoader -All -Unattended -AbortOnError -IncludeDemo -Locale=en -User=wcadmin -Password=wcadmin
INFO 2012-04-17 20:22:49 - joining with std out thread
INFO 2012-04-17 20:22:49 - std out join complete.
INFO 2012-04-17 20:22:49 - joining with std error thread
INFO 2012-04-17 20:22:49 - std err join complete.
FATAL 2012-04-17 20:22:49 - Windchill loader exited with error status = 1
DEBUG 2012-04-17 20:22:49 - ??????????????????????
DEBUG 2012-04-17 20:22:49 - Installation is Aborting. The installation cannot continue.
FATAL 2012-04-17 20:28:46 - Aborting installation.
FATAL 2012-04-17 20:28:46 - Windchill Loader failed.
FATAL 2012-04-17 20:28:46 - aborting: original exit_code = 2
FATAL 2012-04-17 20:28:46 - aborting: normalized exit_code = 2
DEBUG 2012-04-17 20:28:46 - SHUTDOWN REQUESTED
DEBUG 2012-04-17 20:28:46 - (X) commiting registry
DEBUG 2012-04-17 20:28:46 - (X) shutting down service manager
DEBUG 2012-04-17 20:28:47 - (X) cleaning up temporary directories
DEBUG 2012-04-17 20:28:47 - Exiting with exit code: 2
DEBUG 2012-04-17 20:28:48 - cleanUp()
DEBUG 2012-04-17 20:28:48 - calling cleanUpWin32()
