andycpp сказал(а):А ключик к MP3 plugin где взять? старый (36 пост) не катит... Увы.
Не знаю у меня всё катит, 2 keygen'а работают отлично....я проверил..
Hard сказал(а):Например, каких "много багов пофиксили" ?
Нашел в течении 5 минут.What’s New
Notable fixes/changes in version 8.0a
A bug has been fixed that could prevent the Envelope effect from working correctly.
A bug has been fixed that could prevent stereo-to-mono conversions from working correctly when using the Channel Converter.
A bug has been fixed that could prevent synthesis from working correctly when starting with an empty data window.
A bug has been fixed that prevented the play meters from updating correctly when playing AIFF files.
A bug has been fixed that could cause corrupted playback when previewing AIFF files from the Open dialog.
A bug has been fixed that could cause the Plug-In Chainer to lose some of its settings when switching between data windows.
A bug has been fixed that caused the Repair > Copy Other Channel function to fail if no selection existed in a data window.
A bug has been fixed that prevented the Find function from updating the cursor position.
A bug has been fixed that caused the Play at Cutlist command to begin playback at the beginning of the file.
An issue has been resolved regarding preview of selections through plug-in chains that contain automation.
Several improvements have been made regarding VST effect preset handling.
A bug has been fixed that could cause MP3 file lengths to be reported incorrectly.
Various recording issues have been fixed involving input monitoring, DC Offset, and the potential for gapping when you switched away from the Sound Forge window during recording.
The Input Monitor check box has been moved from the Preferences dialog to the Record dialog.
A Record Buffering slider has been added to the Audio page in the Preferences dialog.
A bug has been fixed that could cause your audio driver model from ASIO to MS Mapper when opening a file in Sound Forge from a Vegas or ACID window.
Various enhancements have been made to make playback smoother and refine Audio Event Locator and scrubbing behavior.
The Subject box on the Summary page of the File Properties dialog has been replaced by the Artist box. Subject is still available on the Extended Summary dialog.
A bug has been fixed that could cause changes to ACID metadata to be discarded.
General fixes have been made to make scripting and the Batch Converter script more robust.
ACID metadata — including the ACID track type — is now accessible via scripting.
а у кого-нибудь есть шумодав новый к Sound ForgeKiN сказал(а):Sony Sound Forge 8.0b Build 110
Самый популярный и мощный звуковой редактор, который имеет мощные инструменты редактирования, тысячу различных аудио эффектов и обширную поддержку аудиоформатов. С его помощью можно обрабатывать аудиосигнал, изменяя его до неузнаваемости или же редактировать неудачно записанную партию какого-либо музыкального инструмента.
Notable fixes/changes in version 8.0b:
- A problem with punch-in recording from the Record Remote dialog has been fixed.
- VST plug-in scanning has been improved.
- A bug has been fixed that could cause DirectX and VST plug-ins to remain in the FX Favorites menu after removing or hiding the plug-ins.
- A bug in the Multi-Band Dynamics dialog has been fixed.
- The Set To command on the envelope point shortcut menu in the Graphic Fade dialog now works correctly.
- A bug has been fixed that could prevent you from editing two files with the same file name simultaneously.
- A bug has been fixed that could cause problems with updating meters displayed in plug-in windows.
- A bug has been fixed that could cause the following message to be displayed on startup on systems that included some Adobe applications: "This application has failed to start because PRM.dll was not found. - Re-installing the application may fix this problem."
- A bug has been fixed that could cause processing jobs in the Batch Converter to fail when the Same as source radio buttons are selected.
- A bug has been fixed that prevented Japanese text from being saved with scripts.
- A bug has been fixed that prevented audio preview when using Echo Audio devices with PureWave or default Wave settings.
- A bug has been fixed that could prevent some commands from being mapped to custom keyboard shortcuts.
- Each Open dialog now saves its own most recently used folder list.
- Markers and regions are now saved correctly with .ogg files.
- A problem has been fixed that could prevent CD drives from being recognized on some systems.
оффсайт.
http://mediasoftware.sonypictures.com/products/soundforgefamily.asp
качать.
_http://download.sonypictures.com/current/soundforge80b.exe
_ftp://download.sonypictures.com/current/soundforge80b.exe
кейген.
http://softex.meganet.lt/FIX/08.04/SonySoundForge8.0.KEYGENS.rar
Sound Forge 8.0a build 74
_http://dspcdn.sonypictures.com/current/soundforge80a.exe
Keygen Sound Forge 8.0a
_http://dumpz.ru/attachment.php?attachmentid=5507
Key & Rus для SoundForge8.0
http://sr2.mytempdir.com/107302
на версию 8.0b не идет.
