ACD Systems ACDSee Photo Manager & ACDSee Pro (все версии)
нашёл руссификатор но сам ещё не проверял
"_ttp://www.zhmak.info/2007/05/06/acdsee_pro_20146_beta.html_"
поставил проверил нормально (встало без проблем)
ACDSee Photo Editor 4.0.195 где взять руссификатор
ищу и не могу найти. Всё таки на родном языке приятней и быстрее осваивать.
Qwerza - Пасибка тебе за ссылочку , ну можно чуть поподробнее, что за версия и что там в ней есть ??? Это что "СБОРКА" ???
ACDSee Photo Manager Ver 9 Pro(22mb)
ACDSee 9 makes organizing easy! If you have photos of your kids and friends all over your computer or can't seem to keep track of all of those digital scrapbooking kits you bought, ACDSee is the perfect solution. Use keywords and categories to be sure you can always find just the right image when you need it. For the not so perfect photo, make quick fixes then share with family and friends with high-quality prints, email or your very own online album.
NEW: Faster viewing
See your images instantly onscreen with Quick View mode. Whether opening an e-mail attachment, or double-clicking on a JPEG from Windows Explorer, ACDSee's Quick View mode is the fastest way to view your photos.
NEW: Incredible photo fixes
The Shadow/Highlight tool provides easy and instantaneous correction for poorly exposed photos, without affecting areas of the image that don't require adjustments. With the one-click red eye removal, you don't even have to click directly on the problem area in order to fix it. Just single-click near the reddened portion of the subject's eye and ACDSee automatically fixes it.
NEW: Organize your collection
Calendar Events View automatically organizes your photos based on the date they were taken. You can even add thumbnails to dates in your Events View for convenient viewing and browsing of future and past events. Try Group By - arrange by keyword, size or any other commonly used information. Or get instant results by simply typing a keyword into the Quick Search bar.
Instantly share your images
Create your own stunning slide shows with transition effects and sound - you can even mix multiple audio tracks into your slide shows without the hassle of learning complicated software. A unique function also enables you to synch audio to slides, which makes the slide show last as long as the background soundtrack you've selected. Try the E-mail Sharing Wizard to send images directly from ACDSee without having to open your email application. It can even automatically resize your photos, making them easy to send and receive.
Make home printing a breeze
Print Layout gives you a variety of layout options with helpful wizards that make it easier than ever to print your photos from home. Print multiple 4x6 prints on a single page, or fill an entire page for an 8x10.
NEW: Lock up your special photos
Private Folders protect your personal photos in a secure area so only you can view them. Move any photo to a Private Folder, set a password, and ACDSee Photo Manager will keep them under lock and key.
Easily save and archive your collection
of images to trusted formats, no matter the size. Archive your files in .ZIP, PDF, and many other formats. For all those photos you have on CD already, easily add your collection to the image database on your computer. Then browse through thumbnails of your collection, even images that are on CDs, DVDs and external hard drives, without having to reload them into your computer.
Get extensive format support
for audio, video and images, in over 100 popular formats including BMP, GIF, IFF, JPG, PCX, PNG, PSD, RAS, RSB, SGI, TGA and TIFF. Take a look at the complete list of supported file formats.
ACDSee Pro v2.0.174 РУССКАЯ ВЕРСИЯ
ACDSee Pro представляет собой улучшенный вариант программы ACDSee Photo Manager (последняя версия которой имеет индекс 9), но с более расширенными функциями, рассчитанными на профессиональных фотографов. Среди основных отличительных возможностей этого приложения можно отметить работу с RAW-изображениями, автоматическую сортировку фотографий по параметрам, полученным из цифровых фотокамер, наличие эффективного визуального метода добавления к изображениям метатегов и быструю пакетную обработку большого количества картинок, в том числе и в RAW формате. Кроме того, здесь присутствуют инструменты для независимого регулирования цветовых каналов, исправления артефактов фотографий, появляющихся из-за погрешностей оптики, добавления "водяных знаков", работы с IPTC-метаданными и многое другое. В новой версии появилась поддержка ОС Windows Vista, улучшены многие основные функции.
странно.... у меня никакой активации не попросила, серийник генерил кейгеном олт 10 сентября, тоже коре, программу тянул отсюда _http://files.acdsystems.com/english/installers/acdseepro-2-0-219-en.exe
У меня тоже не поросила ни какой активации !!! Хотя честно говоря пользуюсь ей уже три дня, ни каких революционных отличий не нашёл... Работает так-же как и ДЕВЯТКА.... Вот внешний вид стал, мягко сказать убогий!!! Серый цвет - это уж очень неприятно... С дизайном у них , совсем полный кердык !!!
Хтоя, как не крась АЙСИДИСИШКУ всё равно она ЛУЧШАЯ !!!
Русская версия ACDSee Pro 2.0 сборка 219 (Редакция от 16 сентября)
Русский перевод - Loginvovchyk.
Кардинально улучшен перевод. Окончательно решен вопрос с кодировкой и базами
Теперь просто установите приложение и работайте с ним без всяких манипуляций.
Размер 32 МБ
Ключ продукта не требуется!
Размер 32 МБ
Авторские права:
Разработчик - АСD SYSTEMS INTERNATIONAL INC.
© 2007 Русский перевод - Loginvovchyk.
Украинская локализация ACDSee Pro 2.0.219
Перевод - Lan
Portable_ACDSeePro 2_RUS v2.0.219
Не требует установки, работает с любого носителя.
Ключ продукта не требуется .
Русификация: zhmak
Сборка:pOLARBOND.
Архив с 5%-й инфой для восстановления.
