Elevate Web Builder v1.02 Build 2 + Modules For Delphi XE-XE4
Elevate Web Builder is a 100% visual rapid application development tool for client-side web applications.
It is simple and easy to create full interactive web applications by simply dragging and dropping components on to forms, and then changing their appearance and behaviors as desired.
Includes project templates for creating native modules for use with the Elevate Web Builder Web Server.
:gygy::dance:
thank you PEAKTOP :5:
i could not compile the RichViewActions contained in your package but no problem, it's free just download from site and install.
but the big problem is that i can't find ScaleRichView packages, only TRichView is given !
Could you please provide missed ScaleRichView v5.4.1 packages
thanks again for sharing
VisioForge Video Media SDKs for Delphi 6-XE4
VisioForge Video Capture SDK allows programmers to easily integrate video capturing and processing capabilities into their software applications. VisioForge Video Capture SDK can play and capture video and audio streams from TV tuners, USB capture devices, DV camcorders, PCI capture cards and IP cameras.
Как увидеть ссылки? | How to see hidden links? (перезалил)
Media_Player_SDK_v7.15.7z битый архив, можешь перезалить нормальный?
И на XE4 не ставится, а на XE поставить удалось...
и с IP камерой нифига не работает...
