Debenu Quick PDF Library v9.15
Want to create, render, print, secure, merge, split and manipulate PDF files with just a few lines of code? Enhance your capability with Debenu Quick PDF Library: a powerful, royalty-free developer PDF SDK for adding PDF functionality to your applications.
With over 900 functions for use with C, C++, C#, Delphi (version 4 to XE4), Objective-C, Python, PHP, Visual Basic, VB.NET, ASP, PowerBASIC, Pascal and more – it’s like your ultimate PDF toolkit.
Used by developers of all levels working with PDFs, it’s specifically useful for getting products to market faster. It includes a robust API, and is available in a variety of different editions for including ActiveX, DLL, LIB, Delphi and Dylib. Purchase options include single, multiple developer license or source code license. Support is also included for the most common programming languages.
Debenu Quick PDF Library for Windows
ActiveX - ActiveX COM for Windows development supports C#, Visual C++, C++ Builder, Delphi, Visual Basic, PHP, Python, Java, PowerBASIC and more.
DLL - Dynamically-linked library for Windows development supports C, Visual C++, C++ Builder, C#, Visual Basic, Python and more.
Delphi - DCUs and optionally source code for development using all versions of Delphi 4, 5, 6, 7, 2005, 2006, 2007, 2009, 2010, XE, XE2, XE3 and XE4.
LIB - Statically-linked library for Windows development supports C and C++. 32-bit only.
Добавлено через 1 минуту
Добавлено через 6 минут
JSDialogPack 2.0.025 FS D7-XE4
JSDialog Pack consists of a number of components and helper methods that allows you to add more sophisticated dialogs with ease to your applications. Also included are the numerous components used to create the dialogs. While these components are not registered on the Tool Palette (this may occur officially in the future) they are there for extended use if you choose.
JSDialog Pack currently includes the following dialog components:
TJSDialog
TJSDialogCheck
TJSEditDialog
TJSPasswordDialog (new v1.0.059)
TJSChangePasswordDialog (new v1.0.059)
TJSConfirmPasswordDialog (new v1.0.059)
TJSDualEditDialog (new v2.0.007)
TJSDialogSheet (new v2.0.015)
Добавлено через 7 минут
Elevate Web Builder v1.02 Build 2 (Modules For Delphi XE,XE2,XE3,XE4)
Traditionally, development of web browser applications has been a very tedious process that involves a lot of hand-coding, and experience in several different, but necessary, technologies.Image Desktop application developers have had integrated development environments (IDEs) for years that combine both the design and coding aspects of applications into one unified tool that allows a developer to be very productive. Elevate Web Builder brings this productivity to web browser application development, allowing developers with a lot of desktop application development experience but less web development experience, to instantly create web browser applications. More importantly, it enables the developer to create web browser applications that are guaranteed to contain fewer bugs, and therefore be much more reliable than any hand-coded alternative. A web browser application created with Elevate Web Builder will look the same in all modern browsers, relieving the application developer of the very difficult job of ensuring that all visual controls in their application look and behave the same way. All visual controls are themed, and applications can use any number of themes and can switch themes at runtime.
- A very fast compiler that compiles the source code of any project into an optimized javascript application.
- An integrated, WYSIWYG (What You See Is What You Get) form designer and object inspector that allows the developer to design the visual elements of a web browser application quickly and easily.
- An easy-to-use code editor with syntax highlighting and automated code updating to reflect changes in the form designer and object inspector.
